Home Phone
Land line
newboy
Chat Champion
Message 26 of 26
Hi, I have tried to check on open case for landline. it says fixed on 4/11/2024.
Fault still same but I cannot run connection test as case is open?  which is correct . fault still exists, and cannot reach anyone in chat. Phone no use as I have hearing problems. Anyone assist. Thanks. (needed a rant)
25 REPLIES 25
Message 21 of 26
Hi newboy,
Did you try with the telephone connected to the test socket (the socket under the master socket faceplate)?
How many telephone sockets do you have in your home?
newboy
Chat Champion
Message 22 of 26
Hi Karl,
I have tried an old corded phone I had ,same result. also tried in master socket,  slightly better but still crackly.
Message 23 of 26
OK, before we look to arrange an engineer, just a couple of quick questions.
Have you tested another handset to rule out a fault with this, or tested it at a friends or neighbours so you are sure this is working correctly ?
Have you tested directly at the master socket of 'Test Socket' if you have one ?
newboy
Chat Champion
Message 24 of 26
Hi Debbie,  Thanks for reply,
No, I do not have a no dial tone fault.  It is just very noisy,  crackles a lot.
I am hard of hearing as it is, this just makes it impossible.
Message 25 of 26
Hi @newboy
I'm really sorry about this.
The line tests are clear. Do you have a no dial tone fault?
