on 18-06-2021 12:35 PM
As the subject line says - went to use the phone yesterday and speech is unintelligible. Tried the phone again today, and same fault.
Ring tone appears normal, and Broadband is working. I've changed the filter between socket and phone.
Can the line be checked please?
on 22-06-2021 10:52 AM
Hi Kevin
That's great, thanks for letting us know 🙂
on 22-06-2021 10:44 AM
Hi Debbie,
Yes, thanks, all has returned to normal, I've been testing it over the last couple of days.
Kevin
on 21-06-2021 09:28 AM
Hi -mrt-
Sorry for the delay.
Has this been working ok since your last post?
on 19-06-2021 08:11 PM
Thanks mrt. Pleased to say that as of this morning my phone is back to normal and i have cancelled my engineers visit
on 19-06-2021 07:56 PM
on 19-06-2021 07:49 PM
I too did a bit of digging, and found a reported system problem mentioned on my account dashboard.
As of today, all is now working fine!
on 18-06-2021 05:05 PM
I've had similar problem since yesterday. Speech on my landline distorted and 'warbly'. Broadband fine. Spent large part of afternoon on chat with TalkTalk while they ran tests on my line. End result was that no faults were found and an Engineer visit has been arranged. From past experience I don't have much hope that problem will be fixed soon.
on 18-06-2021 03:39 PM
Hi Karl,
Thanks for your prompt reply!
I don't have a test socket, but 3 hard wired old type sockets. I have disconnected everything from all sockets, and then plugged a good corded phone into the socket that takes the incoming line, via a micro filter, and have exactly the same fault.
I tried ringing a couple of different people, they can hear me OK, but the incoming conversation is as before, totally broken up.
Kevin
on 18-06-2021 01:18 PM
Tests are clear, so no obvious issue detected.
If you have a 'Test Socket' , unplug everything and test an alternative handset only direct at the test socket and confirm the issue is still present. If it is, then an engineer is required.
