Box Unresponsive
eXistenZ
Message 4 of 4
I'm using the TalkTalk TV Hub and have had a couple of instances over the last couple of days where the box has become unresponsive to the remote (both times it's been on BBC 1 HD, channel 101, but this may just be a coincidence).  Pressing "Home" or "Guide" or trying to change the channel hasn't worked and the only way I've managed to restore normal service is to unplug the box to force a restart.
Does anyone know why this might be happening?  Is there a better way to resolve the issue that doesn't involve unplugging the box?
3 REPLIES 3
Message 1 of 4
No Problem 🙂
eXistenZ
Message 2 of 4
I'll try this if the problem recurs and report back.
Message 3 of 4
If you hold down the power button on the remote does it give the shutdown option ?
