WiFi drops tv drops out and can’t get through to customer service
Lozza15
Message 3 of 3
WiFi shocking
4 days trying to contact you
fed up
Remote dodgy as well
tv box slow and unresponsive
Message 1 of 3
Also, what model of TV box do you have ?
Message 2 of 3
The WiFi issue has been raised as an incident and is actively being work on for a solution.
It's on the incident dashboard which you can find here
https://community.talktalk.co.uk/t5/Service-Status-Dashboard/bd-p/service
Updates will be posted there.
