Netgem 4k TV box
vauxman
Message 5 of 5
Just wandering if I can setup my own home screen with what apps I want, ie add Netflix and prime instead of what comes pre loaded,
Thanks in advance
4 REPLIES 4
Message 1 of 5
The order and placement of the apps is set by Netgem directly so this cannot be altered.
Message 2 of 5
I just want to add Netflix, now and prime to the list as I have to go into the app menu then select, seems a silly way to do things, surely to can add to the home screen 🤔
Message 3 of 5
You cannot change the order or install / remove any apps from the Netgem box.
Message 4 of 5
Been a while since I used mine, so can't remember but if you go into apps and select one, there would normally be options if so.
If you search Netgem 4k box manual, you will find a generic guide to download which may help.
