on 16-12-2023 10:48 PM
What apps are available on these small boxes,
I need ITVx and now tv, prime and Netflix.
I've ordered a box but some say now app isn't available, is this true or....
If so I'll have to return it,
Thanks in advance.
on 18-12-2023 08:30 AM
I'm old enough to remember that brand too 🙂
on 17-12-2023 02:26 PM
Sorry,
Just meant your name, I remember the TV brand 👍
on 17-12-2023 12:04 AM
Didn't get the name bit btw?
on 16-12-2023 11:41 PM
You're welcome. 🙂
on 16-12-2023 11:39 PM
Brilliant,
Thanks for your help 👍,
Great name also.
on 16-12-2023 11:35 PM
on 16-12-2023 11:28 PM
Yes it does. 🙂
on 16-12-2023 11:07 PM
Hi ferguson,
Yes it's from talktalk, so should have the Now tv app pre-installed 🤔
on 16-12-2023 10:58 PM
Netgem boxes via retail do not support NOW TV at present as far as I am aware. If you have ordered the TalkTalk variant 4K box then you will be fine.
