TV doesn’t work
Turnip88
Message 3 of 3
Today I noticed that the TV light isn’t lit up on the router and I had difficulty deleting a recording, whilst another failed. The box then kept randomly rebooting. Now I am stuck in a “please wait” cycle and cannot get past the start up screens.
Message 1 of 3
Hi Turnip88
Did you follow the reset advice from fr8ys, and did this help ?
Message 2 of 3
It sounds like your hard drive has failed.
If the following does not work, assuming you have a TV with a freeview tuner, take the aerial out of the TV box and plug it directly into the TV.
try a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try the full factory reset, lose recordings.
Hope it works.
