on 17-08-2022 06:52 AM
If possible could you kindly divulge the nature of the above?
It has seen my speeds drop from 22 to 16. Or is dlm messing around, again.
Answered! Go to Solution.
on 19-08-2022 10:23 AM
That's great news Divsec, good luck with the search for the fault location 🙂
on 19-08-2022 10:16 AM
Best I've ever had here, 39 / 11. Now all I have to do is work out where the fault is in my internals (not your problem) or convince my wife another set of leads and cables is OK.
BBC I player is now offering me UHD content, thanks @Chris-TalkTalk, @Anonymous, @Debbie-TalkTalk for all your assistance and perseverance.
on 19-08-2022 08:21 AM
Morning Divsec,
Sync speed is now 40.9/12.2 following a profile change last night - how are throughput speeds?
on 18-08-2022 03:43 PM
Got thar right Chris factory reset 39 and 9. It's up now if you want a look
on 18-08-2022 03:35 PM
Could you try a factory reset first and if that doesn't work we'll try a replacement
on 18-08-2022 03:31 PM
@Chris-TalkTalk double oops 41 and 8.5. What do you fancy factory reset or replacement?
on 18-08-2022 03:26 PM
Chris I'm going to pop my draytek router on to see what happens, could rule out defective tt kit.
on 18-08-2022 03:10 PM
Hi @Chris-TalkTalk agree 41.6 / 10.6 but only getting as above 21.4 / 10
D.
I also let my deco mesh have a try and that through wired connection to router is the same
on 18-08-2022 02:55 PM
Thanks for trying that. Line test is showing a sync speed now of 41.6/10.6, could you try another speed test and let me know how you get on
on 18-08-2022 02:46 PM
Hi @Chris-TalkTalk and this to my great surprise it directly into the master. Still only showing 21.4 down but 10up now
on 18-08-2022 02:28 PM
Hi @Chris-TalkTalk here we are again, in the master socket, with 30 minute interlude. Quite a difference in the numbers.
on 18-08-2022 12:27 PM
OK thanks Divsec 🙂
on 18-08-2022 10:42 AM
Hi @Chris-TalkTalk not at the moment, it's in the most stupid place imaginable! I'll move it this p.m. and take 30 minutes over doing it.
I'll drop you a line when all is done.
D
on 18-08-2022 09:18 AM
Hi Divsec,
Line test is passing and connection appears to be stable now. There hasn't actually been a profile change since the 9th so the drop in speed seems to be due to something other than a profile change. Is your router currently connected to your test socket?
on 18-08-2022 08:25 AM
Hi @Chris-TalkTalk snooze over, 😜 DLM slept as well and no change. Why does it appear to focus on the upload settings at the expense of download? Is it because I'm left handed👈
on 17-08-2022 12:10 PM
I'll snooze this until tomorrow 🙂
on 17-08-2022 11:10 AM
Perfect, thanks ladies. I'll hold fire on the reboot.
on 17-08-2022 09:31 AM
Ah it's no problem. If the connection now remains stable then hopefully DLM will bring the speeds back up again. Would it be ok if we check this again tomorrow to see if DLM has made any changes?
on 17-08-2022 09:29 AM
Hi @Anonymous phone is fine, there was a storm but 30 minutes afterwards, don't tell me the exchange got knocked about a bit!
I'll try a 30 min reset later in the day. Don't waste your time on me now 🤗
on 17-08-2022 09:17 AM
Thanks for confirming. Is there any noise on the voice service? Did you notice if this may have been weather related? (heavy rain/or thunder)
