Intermittent Disconnects at similar times
adrian555155
Chat Champion
Message 51 of 51
Hi, my internet has been intermittent for a while now I've learnt to cope with it since the internet speed is good. But I was away for 3 weeks and out of curiosity I checked how the internet connection has been through logs and have found out something interesting, check this out.
2022-07-28 22:03:37 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-07-28 22:03:37+00:00 DST], uptime is [1215557s].
2022-07-27 22:03:13 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-07-27 22:03:13+00:00 DST], uptime is [1129134s].
2022-07-22 22:03:38 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-07-22 22:03:38+00:00 DST], uptime is [697161s].
2022-07-18 01:44:21 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-07-18 01:44:21+00:00 DST], uptime is [278407s].
2022-07-15 22:02:51 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-07-15 22:02:51+00:00 DST], uptime is [92318s].
2022-07-10 22:02:41 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-07-10 22:02:41+00:00 DST], uptime is [162132s]
2022-06-29 22:00:57 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-06-29 22:00:57+00:00 DST], uptime is [1679479s]
2022-06-27 22:03:13 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-06-27 22:03:13+00:00 DST], uptime is [1506816s].
2022-06-26 22:03:52 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-06-26 22:03:52+00:00 DST], uptime is [1420455s]
2022-06-24 22:03:05 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-06-24 22:03:05+00:00 DST], uptime is [1247609s]
2022-06-23 05:00:26 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2022-06-23 05:00:26+00:00 DST], uptime is [1099851s].
These are all the disconnects from the router's Log file that were not caused by someone resetting the router. Notice how all the disconnects with the exception of two of them took place at 10PM. Its not just accurate to the hour, but also to the minute. Always within 10:00 to 10:03 margin, it is definitely not a coincidence. The day that it takes place however is completely random.
Any ideas what this could be caused by?
50 REPLIES 50
Message 21 of 51
The router is placed next to a wall but behind that wall is another one of our rooms. I know for fact we do not have any timed devices, not sure about our neighbours however.
Though @Skynet_TX suggested I'd test my land-line with a quite line test at 10pm when the disconnection happens, and while the Internet dropped I heard no noise on the line.
Thats why I think it's not to do with electrical interference, and thought maybe the router software is messing up.
I'd bet on the router fixing it, but if that's not the case the engineer is going to have a hard case to solve.
Message 22 of 51
Hi Adrian
Just a thought, Is the router located near to an internal wall, possibly a neighbouring device affecting the connection at this time?
I have lights set to a timer outside my house, I wonder if something like this could cause interference.
Message 23 of 51
The internet drops for a minute or two.
The other day I was waiting for it to hit 10pm, and at 10:01 caught it happening, the router blinked amber.
Message 24 of 51
Hi Adrian
It may arrive today. If the fault is still present then we will need to arrange an engineer visit.
When the connection drops at 10pm how long is it down for?
Message 25 of 51
It has not arrived yet sadly.
Ever since I connected to the test socket the disconnection at 10pm have been daily. Really hoping this is going to fix it.
Message 26 of 51
Hi Adrian
Has the router arrived?
Message 27 of 51
Hi Adrian
No problem 🙂
Message 28 of 51
Yes please, that would be great.
Message 29 of 51
Hi adrian555155
Would you like me to send a replacement router first?
adrian555155
Chat Champion
Message 30 of 51
It's located next to a printer that is connected to the WiFi. I've not been sent a router and don't have a spare one to test with.
Message 31 of 51
Hi adrian555155
Can I just check, Is your router located near to any devices that could cause any interference?
Have we sent a router for testing recently?
Message 32 of 51
I am unsure an engineer will find anything since a line issue would not have a time schedule. But if you do think its worth trying then please do.
Message 33 of 51
Hi adrian555155
I can see re connections on the line. Would you like me to arrange an engineer visit to investigate further?
Message 34 of 51
It's not every single day, although it has taken place for the past 4 days in a row I believe. And it is always at the same time, the router reports that it resyncs anywhere from 10:00 to 10:03pm.
And we don't have anything on a timer.
Message 35 of 51
Thanks for confirming. Is it always at exactly the same every single day? Do you have any devices set on a timer?
Message 36 of 51
Kids safe / home safe is off.
Message 37 of 51
Can I just confirm, are you using HomeSafe/KidSafe?
adrian555155
Chat Champion
Message 38 of 51
Hey,
Just a quick FYI for TalkTalk support team when they see this post on Monday. On the 31st July or yesterday (Since its 1am on Monday as of writing this), there was a power cut at 2pm, so if you are seeing a disconnect at that time, its because of that. However there was another internet drop out at 10pm that day on the dot, it says router re-synced at 10:02pm.
Skynet_TX
Message 39 of 51
Hmmm, what a strange problem !. When the support team here are back on Monday they will be able to run more detailed tests on your phone line and your router, it is interesting that the site did initially detect a possible problem with your line, so maybe the team here might be able to pick something up on their other tests.
If they did suspect an issue with your router they would be able to arrange a replacement to test with, or if it looks like it is more likely to be related to the external infrastructure then they could get Openreach to investigate further.
Message 40 of 51
Okay, while doing the quiet line on 17070, it was fine, no noise heard. The internet however had disconnected again at the same time, this is while connected to the test socket.
Edit: Just took that test, and it says the line is OK.
Anonymous User
