Intermittent WAN Connection
badappleuktalk
Message 39 of 39
I've tried to speak to the support centre this morning with no luck, I'm having continual network drops from my incoming fiber connection over the last 48hrs.
Please see the attached images, I'm in York and have heard reports of others experiencing the same issues.
The support team over the phone won't help me because I'm not using the standard router, but as you can clearly see, the issue is with the incoming network connection from the street.
This has worked fine for 2+ Years without issue, with no changes on my end.. the issue has to be with the incoming WAN connection.
Please help.
38 REPLIES 38
Message 1 of 39
I'm sorry to hear this and please let us know how you get on today.
badappleuktalk
Message 2 of 39
Unfortunately, I spoke too soon.
The issue, as expected continues.
badappleuktalk
Message 3 of 39
@Michelle-TalkTalk I don't want to speak too soon, but it looks like the new router might actually have improved things, as you can see below.. it's the longest stretch of internet service I've had, since these issues began :
An engineer is still booked for tomorrow which is good as I'd like them to confirm everything has been restored (keeping everything crossed it remains the same)
Improved ConnectionImproved Connection
Message 4 of 39
OK, thanks for the information
Message 5 of 39
Thank @Karl-TalkTalk  if it helps anyones investigations, here are the logs for the last 48hrs :
03.04.202410:50:41ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202410:52:03ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202411:29:35ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202412:56:12ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202412:58:59ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202413:01:26ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202413:04:30ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202413:06:33ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202413:23:01ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202413:25:04ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202413:26:26ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202413:28:37ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202413:46:46ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202414:30:14ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202415:25:50ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202415:27:12ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202418:05:15ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202418:06:37ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202418:39:04ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202418:40:26ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202418:42:59ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202418:45:10ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202418:47:38WRNDHCPC 0 WAN DHCP client (1) stopped
03.04.202421:18:25ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202422:17:09ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202422:34:15ERRDHCPC 0 WAN DHCP client (1) failed
03.04.202422:35:37ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20241:11:42ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20241:13:53ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20241:33:19ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20241:34:41ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20241:36:03ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20241:37:25ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20241:39:24ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20241:40:46ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20241:57:14ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20241:58:36ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20242:48:31ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20243:06:34ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20243:08:31ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20243:09:53ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20243:11:52ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20243:13:14ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20243:50:05ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20243:51:27ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20243:55:17ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20243:57:14ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20243:59:25ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20245:05:18ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20245:06:40ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20245:09:44ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20245:11:06ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20245:53:01ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20245:55:12ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20245:57:11ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20246:14:13ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20246:16:24ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20246:19:44ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20246:58:15ERRDHCPC 0 WAN DHCP client (1) failed
04.04.20248:50:12ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202411:23:05ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202411:24:27ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202412:04:23ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202412:05:45ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202413:30:51ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202413:32:50ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202413:34:12ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202413:36:23ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202413:38:34ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202414:15:38ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202415:02:45ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202415:04:07ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202416:14:11ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202416:16:08ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202416:17:30ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202416:34:33ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202416:35:55ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202416:37:17ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202417:47:35ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202417:48:57ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202418:06:24ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202418:07:46ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202418:09:08ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202418:10:30ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202418:13:15ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202418:14:37ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202418:16:36ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202418:17:58ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202418:20:01ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202418:21:23ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202418:22:45ERRDHCPC 0 WAN DHCP client (1) failed
04.04.202418:40:00ERRDHCPC 0 WAN DHCP client (1) failed
Message 6 of 39
It looks like a standard communication has been triggered incorrectly when they placed the request for the router,  You will certainly not be charged for this.
Can you get back to us after the visit on Monday so our Team can pick this up with you and retest and see how things are going, and if there is need to escalate this further.
Message 7 of 39
@Michelle-TalkTalk Someone has called me and arranged another visit (the 3rd) for Monday… this time they’re going to test a new router (that I didn’t ask for..) I can only assume this is an automated mail / message but please can you confirm I’m not being charged £129 for a new router!
Additional PaymentAdditional Payment
Message 8 of 39
Unfortunately not as all faults have to be raised by us. At this stage I don't know what was identified but my colleague should be able to explain everything when they call you shortly.
Message 9 of 39
Thank you @Michelle-TalkTalk Can i ask what was identified which has led it to being re-routed back to CityFibre? - is there anyone I can contact from CityFibre directly to discuss?
Message 10 of 39
I'm sorry to hear that but I understand. My colleague has just advised me that this was re-raised back to CityFibre yesterday and my colleague will be making contact between 12-2pm today.
Message 11 of 39
@Michelle-TalkTalk I appreciate the message, but I really need this fixing. It feels like it’s going no where and it’s not really been looked into.
The router hasn’t been replaced, but let’s be honest, what are the chances both the talk talk router and my own equipment both have the same issue? Very, very unlikely given everything has been working fine for years up until the planned maintenance works.
As expected, overnight this has continued.
At what point should I seriously consider leaving and signing up to Virgin Media and or any of the other Fibre providers. I don't mind paying to exit, etc I just need a stable reliable internet connection to do my job. Is there a timeframe we can put on this, something like if it's not resolved by Monday the cancellation process should be started?
I can't see how it should take this long to resolve an issue that's clearly on the TalkTalk side of things. It just needs the right people to look at it and work with me on this end, please can you let me know what the plan is please.
Message 12 of 39
Hi again,
I'm really sorry for the delay. I've chased my colleague again for an update and I should hopefully hear back shortly. Can I just check, have we ever replaced the router?
Message 13 of 39
@Michelle-TalkTalk  Did your colleague see anything that could indicate why this is happening so often, I need to understand what the route to resolution is here please, this has been a constant problem since the 26th (at least)..
Message 14 of 39
Great, if it helps your colleague @Michelle-TalkTalk here are more logs, of more drops :
03.04.2024 13:06:42 Info SYS
TR-069 connectivity to (acs.talktalk.co.uk) has been closed
TR-069 connectivity to (acs.talktalk.co.uk) has been initiated
03.04.2024 13:06:33 Error DHCPC
03.04.2024 13:04:30 Error DHCPC
03.04.2024 13:01:26 Error DHCPC
03.04.2024 12:58:59 Error DHCPC
03.04.2024 12:56:12 Error DHCPC
@Michelle-TalkTalk it also looks like another user had the same issues here : https://community.talktalk.co.uk/t5/Fibre/WAN-DHCP-Client-Stopped-issue/td-p/3010239
Message 15 of 39
Apologies, my colleague is looking at this now.
Message 16 of 39
Thanks @Michelle-TalkTalk it's already happened again :
03.04.2024 11:29:48 Info SYS
03.04.2024 11:29:45 Info DHCPC
The WAN DHCP client IP address (removed)
03.04.2024 11:29:35 Error DHCPC
Message 17 of 39
Hi again,
Thanks for the update and I'm sorry to hear this. I've contacted the team now and have asked them what the next steps will be and I'll keep you updated.
Message 18 of 39
@Michelle-TalkTalk  The team have now left and from their readings, everything is fine and there's no issue between the cabinet in the road and the house. I've gone back to basics... talk talk router, plugged into the ONT Box, one device connected via Wi-Fi (this macbook) and within an hour of them leaving the same issue is occurring.
Logs attached below :
03.04.2024 10:50:41 Error DHCPC
03.04.2024 10:52:12 Info WIFI
Device <A2:11:D4:5D:F3:38> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
03.04.2024 10:52:08 Info SYS
Modem login was successful
03.04.2024 10:52:03 Error DHCPC
3.04.2024 10:53:32 Info DHCPC
The WAN DHCP client IP address (removed for security)
03.04.2024 10:53:35 Info SYS
So even after CityFiber have investigated, and with all the TalkTalk equipement, which has been factory restored it's still happening... Please can you escalate to someone who can look at the TalkTalk side of things please.
Message 19 of 39
Ah brilliant, thanks for the update and please let us know how you get on.
Message 20 of 39
Morning @Michelle-TalkTalk  yep, and someone has just arrived to hopefully fix this for good! I've got another call back scheduled for Thursday to check on resolution of the issue.
City FibreCity Fibre
