PPPoE Username and Email
newtovaux
Message 4 of 4
I'm about to setup a non-TalkTalk modem (Vigor 130) and router (MikroTik) for my Fibre 65 package.
What PPPoE username and password should I use?
3 REPLIES 3
Message 1 of 4
No username or password is required for TalkTalk VDSL services, nor do they authenticate via PPPoE, as the help article states.
newtovaux
Message 2 of 4
I'm Fibre65, so I use the VLAN tag ID of 101, however I still can't get it to connect.
I've tried various combinations of using the username 014xxxxxxxx@talktalk.net (e.g. my telephone number), as well as no username, my TT password and no password, but I just can't get the router (or Windows 11 using PPPoE) to connect.
Windows reports a 619 error, and my router just gets into a connecting... connected... terminated... disconnecting loop.
The modem itself if reporting SHOWTIME and shows the correct VDSL2 uplink and downlink speeds.
Is there another setting somewhere that I'm missing?
Message 3 of 4
I've included a Help Guide below,
Set up a non-TalkTalk router - TalkTalk Help & Support
