As we are having to work from home, Could i have my scam protection disabled in order to do this?
Many Thanks
Just because you are working from home, do you actually need scam protection turned off?
yes, when i try to log in on Splashtop it comes up with a scam message, i used my mobile to tether and it logged on straight away, obviously i cant use my mobile all the time as it's using all my data.
Hi Steve
I can turn this off for you, I'll PM you with some security questions.
