WiFi security settings messages and devices offline
papd63
Message 74 of 74
Please can someone tell me what the message 'WiFi security settings have been successfully saved' in my router log actually means i.e. what is the router doing, and why? The message tends to appear multiple, usually 4, times in quick succession, and I get several groups of messages on most days.
My reason for asking is I've been struggling with my wireless printers frequently going offline at seemingly random times. Internet searches show printer-offline issues are widely reported with various printer models, but none of the suggested fixes work for me. Furthermore my problem is affecting two printers (different models) at varying times. So I decided to take a closer look at what is happening in my case...
I ran a batch script which pings my printer IP addresses every 5 minutes over several days to find out when the problem occurs. By cross-referencing the results against my router's log, I've concluded that my problem is somehow linked to the 'WiFi security...' messages in the router log.
To clarify, my 'WiFi security...' messages are usually followed in the log by all 2.4GHz wifi devices - or less frequently all 5GHz wifi devices - automatically disconnecting and reconnecting from the network, and therefore becoming un-pingable for a short time. This is acceptably brief, and is NOT the problem.
The problem IS:
- one or both of my printers becomes permanently un-pingable (ping returns 'unreachable' response) from any device (like my test laptop on wifi, or wired, or my mobile phone) which disconnects and reconnects to the network, AFTER the 'WiFi security...' messages appear. Subsequent pings continue to fail despite the fact that, according to the log, both test device and printer are successfully connected to the network;
- devices that stay connected to the network after the 'WiFi security...' messages, continue to see the printer until the next time they reconnect;
- the only way I have found to make the printer ping-able again from all devices is to disconnect/reconnect the printer itself.
As said above, the 'WiFi security...' messages are normally followed in the log by all wifi devices on one frequency disconnecting and reconnecting. In practice, this can lead to a scenario where the printer becomes un-pingable after one set of 'WiFi security...' messages, and then becomes pingable again several hours later, through being automatically disconnected and reconnected following another set of 'WiFi security...' messages.
In hindsight, my problems will have have seemed random during daily use because firstly, my newer printer can switch between 2.4/5GHz, and secondly, my main laptop running Windows 11 reconnects to the network every time it wakes from sleep. My testing has eliminated these random elements and my printer-offline problems coincide with the 'WiFi security...' messages every time.
So to help me determine where the root cause lies and how to fix it, please can someone tell me what the router is doing when these messages appear, and why do they happen when they do (what is the trigger)?
[ The back of my router says its a Sagemcom FAST 5364-3.T8. The firmware version is SG4K100174. ]
Many thanks in advance.
73 REPLIES 73
papd63
Message 61 of 74
Hi Debbie,
I received my new router (same model) on Tuesday, connected it yesterday evening, and ran an overnight test starting around 9.30pm last night. Unfortunately the results so far aren't very encouraging...
There are groups of 'WiFi security...' messages in the router log at around 02:55, 03:09, 03:23, 03:38, 03:40, 04:09 this morning. On each of those occasions the router log shows that every 2.4G wifi device was briefly disconnected and reconnected.
One of my printers can only connect over 2.4G wifi, and my ping testing (every 5 mins) of that printer shows only brief disruptions overnight, in line with the disconnections and reconnections above. However my other newer printer was connected over 5G wifi, and whilst the router log shows it remained connected throughout last night with no disconnections, my ping testing shows the printer became unreachable from a laptop which disconnected and reconnected to the router at 02:55:20. By contrast the same printer remained pingable all night from a second laptop which stayed connected to the router. As I type, this printer remains pingable from one laptop and not the other.
The logs from last night are somewhat complicated by the fact that the router did a firmware update between 02:50 and 02:53. I'm reasonably confident this had no direct bearing on the results above because the firmware update completed by 02:53, after which both printers returned successful ping responses before the first 'WiFi security...' messages at 02:55. However I'm happy to continue testing for the avoidance of doubt.
The router updated to firmware SG4K100174 overnight, whereas I think it was on something like 130(?) yesterday. Frankly I'm not sure this update was a good thing. I didn't mention it before but my previous router was showing the Internet status as Disconnected, when I clearly did have an internet connection (I reported this via the online chat a while ago but got nowhere and gave up, as it didn't seem to be impacting anything). I was pleased to see this glitch had gone away when I logged into the new router last night, but it now seems to be back this morning. I'd also say the GUI was faster and more stable last night than this morning, or with my previous router. So if you'd like me to test with the previous firmware version and can tell me how to roll back, I'd be more than happy!
I'd welcome any further suggestions on next steps, including any further tests.
Thanks again.
Message 62 of 74
papd63
Message 63 of 74
Ok, I will do. Thanks
Message 64 of 74
Hi papd63
Please let us know if you do experience any of the issues you have reported in this thread.
papd63
Message 65 of 74
Thanks Debbie.
Just to clarify for my testing then, are we saying that the 'WiFi security...' messages should only appear if I make a configuration change, so if they occur at other times then I know immediately there's still a problem? Or are we saying those messages appearing at random times isn't necessarily a problem in itself, I should focus on checking whether it affects my printer connections?
Message 66 of 74
Hi papd63
papd63
Message 67 of 74
Yes Michelle, I'm happy to test a replacement, thank you.
Keith - thanks for your help getting me to this point.
Message 68 of 74
Would you like us to send a replacement router for testing purposes? We would also send a router returns bag so that one of the routers can be returned, would this be ok?
Message 69 of 74
OK, I will ask TalkTalk to consider swapping your router out for another.
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
papd63
Message 70 of 74
No Keith, not at the same time. I get one pair of TR-069 messages once per day, at the same time every day, currently 11.22am-ish. I get groups of 'WiFi security...' messages several times per day, at varying times, day and night.
Message 71 of 74
When you get these messages are there any TR-069 messages at around the same time?
papd63
Message 72 of 74
Hi Keith,
Thanks for replying so quickly!
I haven't been changing the WiFi configuration at all to my knowledge. These messages appear sometimes several times a day, including overnight when I'm asleep. For example there were groups of messages this morning at around 00:36, 02:13, 03:39, 03:43, 06:44 when I certainly was asleep.
I do log in to the router daily, but have only been doing so to get the logs. Each time I logout I get a message "Logging out of your Wi-FI Hub - Be sure to save changes to your settings first" to which the only option is to click 'Yes', even though I haven't actually changed anything. And again, I'm certainly not doing this in the middle of the night when some of these messages appear.
My problem has existed for several weeks, possibly months, I've only focussed on trying to fix it in the last couple of weeks. If the 'factory default' you're referring to is the same as 'putting a pin in the hole at the back' then I did that on June 24th, and since then I've continued to see these message most days, including at 02:40, 03:24, 06:49 on the 25th. (I'm happy to do another reset if you think it would help with any further diagnosis, or if I've misunderstood what you meant please can you explain the steps?)
My only change on the router since doing the factory reset was a few days ago when I set reserved IP addresses, just in case some IP conflict was causing my problem, but it hasn't helped, and the problem and the messages were present both before and after that change.
Could there be anything else triggering the messages, perhaps a connected device misbehaving in some way?
Thanks again, I appreciate your time.
Message 73 of 74
You will get the "WiFi security settings have been successfully saved" log message whenever any WiFi configuration is changed, even things like enable/disable WPS.
Have you been changing the WiFi configuration in the router just prior to getting these log messages? If not, have you tried a factory default of the router's configuration?
