I have 2 laptops that are connected via ethernet that will not connect to internet, this is a recent issue. All other devices (Google homes, chromecasts, server and desktop pc's all work fine.
I have factory reset the router and tried the laptops without anything else connected without any luck. The laptops work at other locations so it's not a end device issue. My router is the new wifihub
Hi Aaron, welcome to the community your post has been flagged for assistance and you should hear soon, don't forget this is a holiday weekend so there may be some extra delay. Please check your community profile and add your landline phone number if necessary it is used to identify your account.
I suspect a firmware update will solve your issue but only the OCE team can implement this.
Hi Aaron
I've updated the router firmer, please retest.
Can you also check the ethernet cable and another port on the router.
Unfortunately this hasn't worked I get the following message on internet explorer.
"There was a temporary DBS error. Error Code: INET_E_RESOURCE_NOT_FOUND" this appears when trying to connect to any website.
Hi Aaron, nearly there. Two things to try, first reboot your router, then try Chrome rather than explorer
Let's know how it goes please
Great news, now go enjoy this fabulous weather😁
Glad it's all working now.....
