Broadband frequently dropping out again!
Paul123E
Whizz Kid
Message 15 of 15
Last month I had an issue where my broadband was dropping out every 10-15 minutes and speed was very slow.
The issue was traced by an OpenReach engineer to a nick in the cable up a nearby pole. Since then we have had a rock solid connection and just under 80Mb/s and, last time I checked, the router had been up for 29 days.
Until Friday that was. Now we are back to where we were. Speed has dropped down and the line will not stay synced for more than 15 minutes.
Could one of you nice people please run a check on my line? Nothing has changed at our end so I assume I will need another engineer visit.
Thanks in advance.
Paul E
14 REPLIES 14
Message 1 of 15
Hi Paul,
That's great news, thanks for letting us know 🙂
Message 2 of 15
Update:
OpenReach Engineer came on Saturday and found a loose fibre in the cabinet. He said it probably vibrated loose which may make sense as we have had some road works recently.
Issue has been sorted and speed now up in the 70's again.
Thanks to all who helped.
Paul E
Message 3 of 15
Our Network Team have advised that the next step will be to arrange an engineer visit so I'm just sending you a Personal Message to confirm some details.
Please do not post any personal information on the Community, reply via Personal Message (PM) only.
Message 4 of 15
Hi Paul123Edwards,
Thanks for confirming this. I've passed this over to our Network Team now. If you don't hear back by the end of today then please can you bump your thread and we can re-check for an update on the fault for you.
Message 5 of 15
Just plugged in the phone and the dial tone sounds normal.
Paul E
Message 6 of 15
Can you check the home phone and tell me if the dial tone is clear or any noise present.
Message 7 of 15
Just a microfilter and the router.
It just dropped out again during writing this reply.
Paul E
Message 8 of 15
Hi Paul,
Do you have anything else connected to the test socket in addition to your router?
Message 9 of 15
I have been direct onto the test socket for all of the morning. It seemed to have got better but was still disconnecting every hour or so. Just had a 10 minute period where it disconnected 3 times.
I work from home so this is causing me problems.
What other tests do I need to do?
Paul E
Message 10 of 15
Message 11 of 15
Will do later and will report back.
Paul E
Message 12 of 15
Hi Paul
Would it be possible to connect the router at the test socket just so we can see if the connection is still dropping in this set up?
Message 13 of 15
Thanks for the fast reply. I did not expect a reply today!
My router is the SagemCom Super Router but I have now switched back to my HG365 router to test. I had a new master socket fitted last time with built in micro filter. I do not have other lines connected but am not on the master socket at the moment. I will try different options and report back. It is behaving exactly like it used to behave when we had an issue with the phone line.
Thanks again for your help.
Paul E
Message 14 of 15
Hi Paul
I've completed a line test which hasn't detected any faults but I can see re connections on the line.
Is the router currently connected at the test socket? Which router are you using? (make and model)
