Connected without internet
Amy449
Message 37 of 37
Help! My phone keeps disconnecting from WiFi saying 'connected without Internet'. I've followed all steps from Samsung who advise me that the issue is not with the mobile (it has been thoroughly checked and works on all other wifi - however to make sure I've followed all steps on my mobile including a factory reset in case it was the phone).  I've had a new router from Talk Talk (Sagemcom model) but it is still causing issue. I've done a factory reset. I've also been put on another channel and had introvert signals sent, however the problem is still present. This connectivity issue only seems to happen on my WiFi at home. If I turn WiFi off and on again on my mobile it's fine and jumps back into action.....the problem occurs a many times per day but can be ok for periods of time in the day, however it takes a manual fix each time and I have to check that the phone hasn't dropped signal each time I use it, so this really isn't good especially if the phone has the screen switched off and it drops during that period,  I just miss so many things on my phone as I'm not aware it's dropped connection. This problem has been present for about 2 months now and is so unstable that I can't use the service that I pay for at home. I'm really unhappy with this service and it just isn't being fixed regardless of multiple phone calls to Talk Talk.
I'm informed from another forum that a different brand router might help, however Talk Talk won't seem to offer me this. Meaning I'm effectively paying for a service each month that I can't use properly. On top of that,  each phone call is about 1hr long and it's a huge drain on my free time to keep trying to sort this.
What can I do? Has anyone got advice on this issue? I'm at the end of the road now with this issue and really need help from Talk Talk.....
36 REPLIES 36
Chris-TalkTalk
Message 21 of 37
Hi Amy
Our devices team are still looking into this, we'll let you know when we have any further information
Message 22 of 37
Thank you for the update. I really need a resolution on this ASAP. Today I have had no wifi through my phone... I'm using so much personal data. I don't feel it's acceptable that I'm still without a resolution for over 2 months and am paying for Internet package that I effectively can't use. If you could update me that would be great. Many thanks
Message 23 of 37
Hi Amy,
Just a quick post to let you know that we've not forgotten your topic and our Devices Team are still investigating this.
Message 24 of 37
Hi @Amy449
I have raised this over to our Devices Team for investigation.
I will post back here as soon as I have further information.
Message 25 of 37
Hi, not in any way, no. I have explored thoroughly this possibility with Samsung just in case but they have checked the phone and it is perfectly fine. It's something specifically with my WiFi that's causing the issue...or at least the communicate only between the two devices (the router and the phone)
Message 26 of 37
Hi Amy449,
Could I just ask, do you have any problems with any other problems with the other android mobile phone?
Message 27 of 37
I think I've done this now and updated this. Any problems and do let me know 👍
Message 28 of 37
Hi Amy,
  • Name
  • Telephone number or Account number
  • Alternative contact number
Message 29 of 37
Hi, Thank you for continuing to help me. My phone is Samsung A34 5g phone. Android 14. One UI version 6.1.
My talk talk router is Sagemcom
Many thanks
Message 30 of 37
Hi Amy,
Thanks for confirming. Please can you confirm the make and model of your handset and also the current version of software on your phone and I can pass this over to our Devices Team for investigation.
Message 31 of 37
Yes I've tried on about 3 different wifi routers for a few days when I've stayed for overnights and no issues whatsoever at any point with being disconnected. It only happens at my home. It's very strange but I have no idea what else to do.
Message 32 of 37
Hi Amy,
When you say that it works on other wifi have you actually tried connecting the phone to someone elses router and used it for any length of time to see if the same thing happens?
Message 33 of 37
Yes I've tried all sorts on my phone: forgetting wifi, clearing cache partition, soft reset, factory reset, safe mode... everything. Router wise, I've done a factory reset and had a new router but the problem is happening all the time. It only happens on my home WiFi. It's getting to a point now where I just can't use it.... something more really needs to be done as I feel I'm just paying for a service that I can't use now. Can anything more be done?
Message 34 of 37
Hi Amy,
Have you tried forgetting the TalkTalk wifi connections on your mobile phone and then reconnect, re-entering the wifi password?
Message 35 of 37
Thank you for getting back to me and for trying to fix this issue - really appreciate your time on this for me. Unfortunately this has not solved the issue. The issue has just happened whilst I sat here to reply, I've logged on to my router setting via my PC - my mobile, Laptop and my Mum's phone are all at the moment on band 1 (2.4Ghz) - however my phone is saying 'connected without internet' and it has switched me to my mobile data instead, however all the other devices other than my mobile are still connected and working perfectly to the wifi. Why is just my phone losing the connection? It is not that my phone has stayed on a different band to the others, they are all on the same band, but it is my phone that gets booted off for some reason. This only happens in my house on this wifi, there must be something wrong with how the wifi and the phone are connecting. I don't understand what is causing this issue, but I've had my phone for 7 months with no issues, and suddenly it's started to happen. I have looked into phone faults and factory resets etc but Samsung have assured me it is not a fault with the phone and the fact that the phone is fine on all other wifi indicates it is how it is communicating with this Talk Talk wifi in particular. Can you help further as I just can not use this wifi service properly now.
Many thanks
Message 36 of 37
Hi Amy
Just looking at the Wi-Fi connections to the phone,  I can see some issues with Bandsteering, and the device refusing to switch between 2.4Ghz and 5Ghz bands when requests are issues.
I've made a change here to see if this improves the situation.  Can you try the connection over the course of the day and see if there is any improvement.
