Fibre installation failure - engineer responsible for lack of internet
mrpotatogod
Message 49 of 49
My internet connection was never the best and my contract with talktalk has almost ended so I have decided to upgrade my broadband to full fibre 150 (before I had mixed copper line 65)
I thought changing cables to fibre might help with my connection.
So on 26/11 the engineer came to install full fibre at my house.
First thing he did was he cut off the old copper line (leaving me with no internet connection at all) and replaced it with fibre.
Unfortunately as it turned out the engineer was unable to complete the work on 26/11 due to a lack of equipment and blocked/congested duct. A second engineer is required.
So basically now I am left with no internet connection at all.
First I was promised by talktalk that the new engineer will be assigned within 5 working days.
This did not happen.
So then you have raised an escalation case with Openreach a reference Case Number -00032683 and Openreach was to contact me within 24 to 48 hours.
So now I don’t know what to do. I am clearly being ignored. I am seriously thinking about switching to a different broadband provider.
I just want to mention that I work from home and I am often on conference calls therefore I need stable internet connection. This past week has already affected my work quality and I cannot afford to have no internet connection. I am using my mobile phone for internet but the reception is not so good therefore connection is bad.
Is there anything you can do to help? If you cant send a specialized engineer to connect full fibre can you at least send someone  to connect the copper line back to me asap? I know that the old line is still active.
I am desperate and I would really appreciate any advice.
Kind regards
48 REPLIES 48
Message 41 of 49
Thank you Chris for an update. Another week with no internet 😞 I hope I will not be charged for the FTTC service as I do not receive ANY service from talktalk atm - and it is not of my fault.
Message 42 of 49
Our provisioning team have said that there's Civil works required to complete the FTTP installation, this looks like it will be on the 12th. Unfortunately there nothing that we can do in the meantime to reinstate the FTTC service, I'm really sorry for the inconvenience
Message 43 of 49
OK thanks. Leave this with me and I'll check with our provisioning team and get back to you
Message 44 of 49
He disconnected me from the old service thinking that he will connect me to the new service which then turned out he could not because of the blocked pipe. He did not reconnect me to the old service afterwards.
So now, no new nor old connection 😞
The engineer made a mistake cause first thing he should do is to make sure that he is able to connect me to the new service and make sure that everything is fine and THEN disconnect the old connection.
Message 45 of 49
I see, so he disconnected your old service knowing that he couldn't complete the install of the new service?
Message 46 of 49
I do not use  telephone line. The engineer has cut off the copper line so my router is not connected to anything as there is no line to connect to. The service might be active from your side but I am physically not connected to any cable as it was cut off outside my house.
Chris-TalkTalk
Message 47 of 49
Hi mrpotatogod,
Is your telephone line completely dead, no dial tone? The service appears to still be active from our side?
Message 48 of 49
That is really not right, they should not have cut off your existing connection before checking that the new one was live. This has been flagged up to the support team here and they will do their best to help you resolve this mess.
Anonymous User
