Fibre installation failure - engineer responsible for lack of internet
mrpotatogod
Message 56 of 56
My internet connection was never the best and my contract with talktalk has almost ended so I have decided to upgrade my broadband to full fibre 150 (before I had mixed copper line 65)
I thought changing cables to fibre might help with my connection.
So on 26/11 the engineer came to install full fibre at my house.
First thing he did was he cut off the old copper line (leaving me with no internet connection at all) and replaced it with fibre.
Unfortunately as it turned out the engineer was unable to complete the work on 26/11 due to a lack of equipment and blocked/congested duct. A second engineer is required.
So basically now I am left with no internet connection at all.
First I was promised by talktalk that the new engineer will be assigned within 5 working days.
This did not happen.
So then you have raised an escalation case with Openreach a reference Case Number -00032683 and Openreach was to contact me within 24 to 48 hours.
So now I don’t know what to do. I am clearly being ignored. I am seriously thinking about switching to a different broadband provider.
I just want to mention that I work from home and I am often on conference calls therefore I need stable internet connection. This past week has already affected my work quality and I cannot afford to have no internet connection. I am using my mobile phone for internet but the reception is not so good therefore connection is bad.
Is there anything you can do to help? If you cant send a specialized engineer to connect full fibre can you at least send someone  to connect the copper line back to me asap? I know that the old line is still active.
I am desperate and I would really appreciate any advice.
Kind regards
55 REPLIES 55
Gliwmaeden2
Message 1 of 56
@DanM89,
Please start your own thread if you need further help.
Staff are replying to @mrpotatogod on this one, and it really can cause confusion if you piggyback for your own case.
Similarly here:
https://community.talktalk.co.uk/t5/Full-Fibre/Installation-PTW-Permission-to-work/td-p/3096253#M403...
So please return to the message board and click on start a topic if you need help for your specific situation.
Message 2 of 56
At the moment there is no time frame for further updates please do contact our full fibre team using the contact number below, thanks.
: 03451720074
Opening Hours:
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
Message 3 of 56
Thank you for your quick reply.
Yes apparently there is a blockage in the duct stopping the fiber cable from being installed on my street to. It was found during the original installation on the 12th May. Have you been given any indication on timeframe for a resolution ?
Dan
Message 4 of 56
Hi there @mrpotatogod, thank you for reaching out. Surely Openreach is working on that blockage. Kindly please keep on checking availability in your area.  https://new.talktalk.co.uk/check-availability
Message 5 of 56
Hi there @DanM89 I am very sorry to hear that you have issues with your installation. We will reply to your previous post. Thanks
mrpotatogod
Message 6 of 56
Hi Dan,
I’ve been reconnected to the copper line by TalkTalk and received my auto-compensation refund for the service disruption (thanks to Ofcom's help, as TalkTalk initially refused to acknowledge their fault).
Unfortunately, I’m currently unable to switch to full fibre due to a blockage in the street. Openreach is working on resolving the issue, but I’ve been waiting for several months with no progress, so at this point, I’m essentially stuck with the copper line.
What concerns me is that all providers are planning to switch off copper lines by the end of 2026. If my situation doesn’t change, I risk being left without any broadband connection at all.
Message 7 of 56
I am currently in a similar situation regarding permissions.
Are you able to share your experience of how you managed to get this resolved ?
Dan
Message 8 of 56
Hi mrpotatogod
Its has been raised to the Auto compensation team and is under review at the moment.
You will receive a SMS/email one its completed.
Message 9 of 56
You need to raise a formal complaint with TalkTalk first. If they do not resolve it to your satisfaction within 90 days and/or you receive a deadlock letter then you can raise it with Cisas.
mrpotatogod
Message 10 of 56
Hello TalkTalk Community,
I’m reaching out because I’m having trouble with TalkTalk regarding compensation for a significant service disruption I experienced.
On 26th November 2024, I had an engineer visit to install full fibre broadband. However, the engineer cut off my old copper line and was unable to complete the work due to lack of equipment and a blocked duct. This left me without any internet connection until 7th February 2025. During this period, I had no service at all, which severely impacted my ability to work from home.
I’ve requested compensation for the time I was without service, but TalkTalk is only offering £13, which is far below the amount I am entitled to based on their compensation policy. I am seeking £9.76 per day for each day without service.
Since they have refused to provide the appropriate compensation, I am now seeking help from CISAS to resolve this issue.
Has anyone else encountered a similar problem, or can you offer any advice on how I can proceed with CISAS?
Thanks in advance for any help!
mrpotatogod
Message 11 of 56
I am sorry but this is a one big joke and I need to share this with everyone.
After two months of patient wait from my side I get this message from TalkTalk:
I apologise for the inconvenience, but OpenReach wants to cancel this order because they are unable to obtain the necessary permissions. We have tried to contact them to inquire about the reason, but they are unable to disclose it due to GDPR regulations. I believe the best course of action would be to allow the cancellation of this order, and once it has been processed, we can attempt to place a new order.
I seriously do not know what to do.
So basically TalkTalk:
1 Left me with no internet connection for 2 months now (you did not want to reconnect old copper line gods now why? The Copper cable is in front of my door)
2 Cant find out why the OpenReach do not want to carry out the necessary work (what permission do they need – this is a private road and I have already signed PTW permission to work)
3 Do not want to give me details of the case so I could personally contact Openreach about this (why not?)
4 Have no plan whatsoever and do not give a ….. about their customers
Is this correct or am I missing something ?
I am furious, I did not expect such incompetence from TalkTalk
Message 12 of 56
The notes show  it is stating they need permission from various teams usually means local authorities.
Sorry
Message 13 of 56
I am sorry but I am confused. Who is '3rd Party/ customer'?
On 16/12/2024 I have received a Signature requested on SD PTW Form from Openreach.
I have signed it and send it back on the same day and i have received an email confirmation from them: 'You signed: "SD PTW Form PTW@support.openreach.co.uk - OGEA16054647 - 1ST PARTY"'
So what permission they are waiting for? If they give me any details maybe I can help.
Now I have been more than 2 months with no broadband connection and if the openreach keeps waiting and postponing the works I will never get reconnected...
Message 14 of 56
Hi mrpotatogod
I  have checked and the response was "we are waiting for the signed copy of permission to work by 3rd Party/ customer,  in order to progress with the duct work. Please do not reappoint until signed documents are provided.
Have you been sent anything?
mrpotatogod
Message 15 of 56
hallo, anybody?
mrpotatogod
Message 16 of 56
Hi, Today I have received a message from Openreach :
‘It's Openreach on behalf of TalkTalk. Here are your new Full Fibre installation appointment Date: Thu 13 Feb:’
Can anyone please check if previous date of my installation appointment: 05/2/2025 is still valid and the new appointment is an additional appointment or they have postponed the old one to new date?
Thank you.
Message 17 of 56
Message 18 of 56
Thanks guys for a quick replies. Kind regards.
Message 19 of 56
Hi mrpotatogod,
I can see that Gliwmaeden2 has answered your question, I'm sorry this is taking so long to resolve
Message 20 of 56
You won't receive any communication about automatic compensation until AFTER it's resolved, @mrpotatogod.
They can't begin to process it until they know the particular number of days etc.
