New TalkTalk Booster not working
on 29-07-2024 12:51 PM
Message 48 of 48
I have fibre 65 internet and it works fine.
Received the new Sagemcom F@st 266 UK V2 booster from talktalk the other day. The setup works fine and it goes through the lights, etc.. and it "works". i.e. solid blue light after the WPS procedure. But after a minute or two the light changes to flashing orange and it no longer works.
Have restarted the router and booster numerous times and the same always happens.
Setup is done very close to the router. The router is also compatible. Its a Sagemcom Fast 5464.
Is something wrong with my booster?
Labels:
- Labels:
Connection
Other
Router
Wifi
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
47 REPLIES 47
on 19-08-2024 06:00 PM
Message 21 of 48
Do you remember the 266 flashing blue & green indicating it was trying to update its firmware? If so, which side of the router being updated to V202?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
19-08-2024 02:52 PM - edited 19-08-2024 02:55 PM
Message 22 of 48
Firmware 158 was the minimum for the V1 F266 booster, V202 is the minimum for the V2 F266 booster. Your SSIDs are strange, because you were connected to a totally different SSID before, that contained the word "Van". In your AP view screenshots the Shell networks are only shown in about one of those.
Please can you log into the router & go to (assuming the desktop version):-
Dashboard > See Wi-Fi Settings > Manage Advanced Settings > Wi-Fi 5Ghz gear icon > Wi-Fi Mesh
From there, go to the Overview, then Extenders sub-tabs and get me screenshots of each one.
The WiFi scan throttling will not improve anything, it just means that the WiFi analyser will keep checking for new networks.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-08-2024 02:19 PM
Message 23 of 48
Just tried it all again with wifi throttling off and got the same results. Once the connection is established the "shell-857c70" AP appears for both 2.4 and 5GHz and after a minute they disappear the the amber light starts flashing. No other AP appears at all during the whole sequence.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-08-2024 01:58 PM
Message 24 of 48
Hi All,
Thanks for this.
I thought the minimum FW version was like 156 or something from reading other posts... anyway, it now is at 202 and it behaves exactly the same. Restarted my router and the extender then did the setup twice. same results as before. Works for 1 minute and then it crashes.
@KeithFrench , yes it is, the V2 F266 is called "SHELL-857C70" on my screenshots. This only shows up for the minute the light starts solid blue. once it blinks amber the "SHELL" AP disappears. The first extender had a similar name "SHELL-3200". You will see that the "shell" AP only appears on the screenshots that I named (Extender ON and solid blue light).
Regarding the SSID name, that's correct, I need this in order for other smart devices in my home to work. Most of them only work in the 2.4 GHz frequency.
I can try disabling the wifi throttling, will let you know if anything else shows up.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-08-2024 01:13 PM
Message 25 of 48
Your V2 Fast266 is not displayed in any of the screenshots that you have sent me. Please can you repeat them, now that @Karl-TalkTalk has updated your hub's firmware.
One other point, you have split the SSID (network name) into two different ones. Whilst I doubt if this is the cause of the problem, the Hub & Fast 266 all need to use the same SSID. Please can you reconfigure them?
I notice also that your WiFi analyser is reporting that Wi-fi scan throttling is enabled on your Android device running the WiFi analyser. This is not to be recommended, as it limits the number of networks detected in a short time period. This could mean that the SSIDs from the 266 might be present, but are not displayed due to this Android feature being enabled. To disable it, please see this article:-
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-08-2024 12:54 PM
Message 26 of 48
The Hub firmware V202 is the minimum required to work with the V2 F266. So if your testing was done before @Karl-TalkTalk updated the router's firmware, then you will need to retest.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-08-2024 12:15 PM
Message 27 of 48
Whilst Keith is looking at this, I've updated your router firmware for you.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-08-2024 11:59 AM
Message 28 of 48
Hello @Anonymous , @Chris-TalkTalk , apologies for the delay in getting back to this.
The new extender does exactly the same as the original, it does not work. Setup is fine for 1 minute (solid blue light) and then it crashes again.
@KeithFrench , thanks for the guide. I have taken the screenshots and will be sending them to you via PM just now. Thanks again for assisting with this.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-08-2024 06:49 AM
Message 29 of 48
How are you getting on?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 01-08-2024 07:14 PM
Message 30 of 48
I forgot to say, please don't use NetSpot as in this case, it won't give me the information that I need.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 01-08-2024 02:54 PM
Message 31 of 48
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 01-08-2024 02:03 PM
Message 32 of 48
Yes, please send the guide over and I can get you the screenshots.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 01-08-2024 11:05 AM
Message 33 of 48
How are you getting on, do you want me to supply you with my guide on getting me the diagnostic information from a WiFi analyser?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 31-07-2024 10:59 AM
Message 34 of 48
The booster needs to be on, but in a failed state.
The firmware that you have on your router will be V174 then.
Do you have an analyser & if so which one, as not all will display the information I require? I can send you my guide that covers the best free WiFi analysers & how to use them if you want. I would need to see screenshots of the main AP view & the 5GHz channel displays,
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
31-07-2024 10:37 AM - edited 31-07-2024 10:38 AM
Message 35 of 48
Hi Keith,
The last digits of the firmware was 177 if I remember correctly.
What information would you be after on the wifi analyser? Does the booster have to be on during the check? If so, what stage do you want it in? I.e. solid orange (ready to pair) or when it is blue for 2 minutes after setting up?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 31-07-2024 09:55 AM
Message 36 of 48
I am helping another customer currently, who also has the Version 2 FAST266 booster and is experiencing an unstable connection like yours. What firmware is on your router?
To confirm if this is the same issue or not, I will need you to run a free WiFi analyser app for me & get me some information from that. If you are happy to do this, with my help every step of the way, then please let me know.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 30-07-2024 08:33 AM
Message 37 of 48
OK, I've ordered the booster and a returns bag to send the old one back in
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 29-07-2024 02:31 PM
Message 38 of 48
Hi Chris,
Yes, if you can that would be great. Thanks.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 29-07-2024 02:10 PM
Message 39 of 48
OK thanks for trying. I can arrange to send another booster to test with, would you like me to do this?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 29-07-2024 02:08 PM
Message 40 of 48
Hi, the guide you sent is not for the booster I have. My booster only has 1 LED light. Regardless, I have followed the setup that came with it in full and it still does not work. The guide is similar to the one you sent but it has different LED responses, button hold times, etc...
The issue is still the same, it connected for 2 minutes and then goes into "error" mode.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
- Problems getting old land line number ported over from closed BT account to new TalkTalk land line in Home Phone
- Non-working setting in TalkTalk webmail in Email
- Internet down on TalkTalk side, test connection service returns an error in Broadband
- Talktalk broadband router no longer supported by manufacturer. in Broadband
- ROUTER STOPPED WORKING in Broadband
