on 10-10-2021 02:59 AM
Hello
I have
problem with Talktalk router
I need port 44158 open for bobcat miner to work properly , its connected with LAN cable so its givin me auto 192.168.1.10 but i reserve it anyway and then i go on port forward to add rule for 192.168.1.10 to open port 44158 but no luck so far , ive make few screenshots hopefully im missing something
PS - firewall it was on medium which is blocking NETBIOS and im not sure if that is related so i put firewall on low - allow all and on portchecker.co still says "closed" Please help , thanks
Answered! Go to Solution.
on 10-10-2021 01:31 PM
That rule will never work because you have set an external host to the local IP address of the device. This field needs to be left at its default of *.
There is no need to change the firewall on the router at all.
This port forwarding rule works perfectly:-
