Router problems - again
F10rrell
Chat Champion
Message 14 of 14
Been having trouble with internet and WiFi for a couple of weeks. First of all the Chromebook lost connection so, eventually, I restarted the router and that seemed to work but then at the weekend the grandchildren said they had no WiFi and we found the TV had none either. Our mobile phones and the TT box had connection but nothing else. I tried unplugging everything from the router, waiting for around 15 minutes and plugging back in, that got everything connected again - for a while. Then I resorted to he reset button and that worked - for a while. Now we're stuck with an amber flashing light on the router and no Wifi! I have also plugged the router directly into the test socket but nothing changed.
Please has anyone any ideas??
Lesley
13 REPLIES 13
Message 1 of 14
I'm really glad to hear that and thanks for confirming 🙂
Message 2 of 14
Morning
Yes thank you, still working fine at the moment! 🙂
Lesley
Message 3 of 14
Just checking back in to see if everything is still ok with the replacement router?
Thanks 🙂
Message 4 of 14
Message 5 of 14
The previous router was posted yesterday evening and should arrive by Monday
Lesley
Message 6 of 14
Thanks for the update and we'll check back in with you early next week just to check that everything is still working ok with the replacement router 🙂
Message 7 of 14
The router has been delivered and is now set up. Everything seems to be working fine with this one, so far.
Thank you for your help.
Lesley
Message 8 of 14
Hi F10rrell
No problem. Please let us know how you get on.
Thanks again
Message 9 of 14
Hi Debbie
Thank you. I'll look forward to receiving it and seeing how it works out.
Lesley
Message 10 of 14
Hi F10rrell
Message 11 of 14
We have had some problems with the phone line that should have been corrected, though it is still noisy sometimes. Maybe a replacement router would help? Though this one hasn't been in use very long so it would be good to find out why it's gone wrong so soon!
Thank you.
Lesley
Message 12 of 14
I'm sorry to hear this. I've run a test on the line now which hasn't detected a fault. Is the voice service ok with a clear dial tone? Would you like us to send a replacement router for testing purposes? We would also send a router returns bag so that one of the routers can be returned.
Message 13 of 14
Hi @F10rrell
That sounds like a fibre or router issue to me.
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
