on 26-10-2020 08:55 AM
I upgraded my plan to Fast Fibre a couple of weeks ago. However, it's been a painful experience so far.
The connection and download speed is not stable, especially during working hours. I'm working next to the router and double checked everything is set up correctly. During weekends or in the evening I easily reach +130mbps, but during working hours I regularly lose connection or only reach a mere ~10mbps.
I was actually better off with normal Fibre rather than Fast Fibre.
Some others who experience troubles with stability of Fast Fibre connection?
on 28-10-2020 08:43 AM
Hi ThibaultD,
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 26-10-2020 08:57 PM
Hi @ThibaultD ,
It would be worth going to the Service Centre to do a test on your phone line, this will indicate if there is currently a fault on your line. You can also access this from the ‘My Account’ site.
Then they will hopefully be able to respond to this post within a day or two.
