Wi-Fi Optimisation
WaRRioR1976
Whizz Kid
Message 3 of 3
Hi. I realise that Wi-Fi Optimisation  can't be switched off now, but it is causing me problems. Tonight for example, as would be expected on a Sunday night, all the Wi-Fi channels on the 2.4 ghz band are quite congested. Unfortunately my TV in the lounge can't find the 5 ghz band. Every few hours the router switches to a different channel which is a problem because if I'm watching YouTube or Netflix, it buffers and loses connection. There shouldn't be any buffering because my current download speed, according to my router, is 77mbps and I'm not using a lot of devices at the same time, usually just my Smart TV and smart phone.
I know TalkTalk have said it can't be switched off, but I can't understand why they won't do this if its what the customer wants and if it improves the customer experience.
Is there anything I can do about this, please?
Thank you.
I'm a drummer in a very well known band, I'm also a world class racing driver and crazy golf world champion 7 years in a row. Please note - I'm a bit of a dreamer and try and make my life sound more interesting than it is, so the above statement might not be true.
Message 1 of 3
Hi @WaRRioR1976
Apologies for this.
I can see that @KeithFrench has offered to help.
KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue.  Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others.  If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc.  one of the TalkTalk team will jump in and help out.
Message 2 of 3
I will need to provide TalkTalk with evidence as to what is going wrong.
