Wi-Fi signal fluctuating
Ganger
Message 7 of 7
Since receiving a new Sagem-Fast 5364 router in February my wi-fi signal has always fluctuated and I never have a full signal. The problem is more prevalent now. This never happened with my previous router which I was told was not suitable for Fibre 35. Do I have a faulty router?
6 REPLIES 6
Message 1 of 7
Hi Ganger
That's great, please let us know if you do experience any further issues.
Debbie 🙂
Message 2 of 7
Full stable signal now. Thank you.
Message 3 of 7
Hi Ganger
I have switched the WIFI optimisation off. Please can you try a few different wireless channels to see how the connection compares?
Change your wireless channel - TalkTalk Help & Support
Message 4 of 7
Yes, the wired connection is O.K.
Ganger
Message 5 of 7
Yes. The wired connection is working O.K.
Message 6 of 7
Hi Ganger
Can I just check, is the wired connection working ok?
