WiFi dropped
Tony8blogs
Message 14 of 14
I am having a similar problem as reported by Amy449 in July with the WiFi being dropped to my mobile phone. The final reply to Amy from Karl of the TalkTalk team was...
Just looking at the Wi-Fi connections to the phone,  I can see some issues with Bandsteering, and the device refusing to switch between 2.4Ghz and 5Ghz bands when requests are issues.
I've made a change here to see if this improves the situation.  Can you try the connection over the course of the day and see if there is any improvement.
Please check into this and see if I am experiencing a similar problem.
Regards, Tony
13 REPLIES 13
Message 1 of 14
I have seen on a couple of samsung forums that this is an issue with one of the chipsets used and affects several models of their mobile phones. Unfortunately samsung are slow to respond to or acknowledge this. I see a number of people suggesting using other makes of mobile phone for their next choice, worth considering if they don't value customers and their feedback. Thank you very much to all on here for your assistance along the way.
Kind regards, Tony
Message 2 of 14
Hi @Tony8blogs
@Michelle-TalkTalk has asked me to help you. When you say that you are just using one band, how are you doing this? If you are using a Sagemcom router and disabling the bands within the router UI, there is a bug in the firmware preventing them from restoring correctly. The only workaround to this is to do a factory reset of the router.
Message 3 of 14
@KeithFrench - would you be able to offer any additional advice please?
Message 4 of 14
I have been checking the connection on the 5GHz only configuration and the WiFi is still dropping. I went back to both 2.4 and 5 GHz bands and back to normal dropping also. Next I changed to using the 2.4Ghz band only. This was slightly better with the WiFi dropping but a lot less often. Sadly the problem persists all be it far less often. I'm unsure what can be changed further to improve matters.
Regards, Tony
Message 5 of 14
Morning Tony,
How has your connection been over the last 48hrs?
Message 6 of 14
Since making the initial change of dropping the router for over 30 minutes and power cycling the phone the WiFi is still being dropped but less frequently. I have renamed the 2.4Ghz channel as this is not heavily used in the home and should cause least disruption to users. I will see if the change helps the overall situation and report further over the coming days.
Regards, Tony
Message 7 of 14
You can log into the router and separate the 2 Wi-Fi channels   by renaming one of them and see if this helps.  This can test to see if the phone remains connected to one band permanently.
Message 8 of 14
Chris, I carried out both of these actions and unfortunately the problem persists. I get reports on the phone WiFi of connected without internet. I'm afraid I was sceptical of this and feel a more in depth technical solution is required. I think what is  required, from as  I stated in the original message, is an analysis of what is happening at the router. Where the solution was found to be relating to band steering and a change being made in relation to that.
Regards, Tony
Message 9 of 14
Thanks. Could you switch your router off and leave it off for at least 30 minutes, then switch back on. Could you then switch your mobile off and back on. Please let us know how you get on
Message 10 of 14
Hi, I have a Samsung A34 5G.
Thanks, Tony
Message 11 of 14
Hi Tony,
Which mobile phone do you have?
Message 12 of 14
Debbie, that is correct. The mobile phone drops the WiFi. As I stated, having read the thread, it looks similar to that reported by Amy449 and answered by Karl. Grateful for any help.
Regards, Tony
Message 13 of 14
Hi Tony8blogs
Just to confirm, is it only the mobile phone dropping WIFI connection?
Please can you add your name and TalkTalk landline number to your Community Profile.
