can't turn on wi-fi on router, even after a reset!
spookszilla
Message 15 of 15
Hi, I have had fibre installed, and my router is a Fast 5464-2.T4 with it's control panel software SG4K100174, and try as I might, I can't turn on both wi-fi channels. I have tried using the control software, resetting it, and even unplugging all cables, letting it sit, and re-connecting again, I even did another reset, and no dice! Is there a problem with the firmware or the modem itself?
14 REPLIES 14
Message 1 of 15
Morning @spookszilla
Just checking back in to see how you're getting on?
Message 2 of 15
No problem, hopefully you'll have no problems with the new router
Message 3 of 15
Ok, that's super!
I think the message to take from this is to never turn off the Wi-Fi!!
Message 4 of 15
Hi spookszilla,
I can see that Karl is sending a replacement router, it should be with you within a couple of working days
Message 5 of 15
Ok, tried Avast Secure Browser, logged into the dashboard, clicked on 'see wi-fi settings' tried to turn on wi-fi, but still showed 'disabled'
Message 6 of 15
My PC is running Windows 7 Home ( bit of a luddite, me!) and my browser's Firefox.
Message 7 of 15
I'm going to swap out the router.  A new one is on the way.
Message 8 of 15
Yes please, Due to work hours, I can be strapped for time - I had to get time off work today to get stuff sorted out!
Message 9 of 15
Ok Chris, Community profile updated!
Message 10 of 15
Do you still need assistance with this?
Message 11 of 15
Hi spookszilla,
  • Name
  • Telephone number
  • Alternative contact number
Message 12 of 15
Hi @spookszilla that really is an odd one (sorry no consolation to you)
Try to access the router using another browser, there is a good but esoteric reason this can help but it is far from my knowing.
Either way it will help the team tomorrow to sort things out for you, could you also advise when you have a chance which operating system and browsers you are using.
Thanks a lot
D
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support.
spookszilla
Message 13 of 15
Hi Divsec,
When I first set up the router, wi-fi was on by default, can't remember when, but I switched it off on the control software, thinking that I could switch it back on whenever I wanted.
I totally forgot about it, probably for a couple of months until I tried to use my Amazon Fire stick, and I checked on my mobile phone to confirm that there was no wi-fi from the router!
Divsec
Message 14 of 15
Hi @spookszilla has WiFi ever worked? And if yes did anything change?
