Fiber 65 customer setting up a Eerro 6+
Legend2
Message 27 of 27
I've been getting a lot of ping/lag when multiple people are on the internet. Was looking at setting up a Eerro 6+ to hopefully help fix these problems. The problem is I don't have a modem, is it still possible to disable the wifi on my router so I'm using the Eerro instead?
26 REPLIES 26
Message 1 of 27
You're very welcome.
Message 2 of 27
Seems much better at the moment, thank you for all your help, I really appreciate it 🙏
Message 3 of 27
See how it goes & if needs be, I'll address them as & when.
Message 4 of 27
That seems to have done the trick and the internet is now working with the manual IP. Would I need to do anything else?
Message 5 of 27
Try to do a Restart network via:-
Settings > Network Settings
Tap the 3 dot icon in the top right of the window, then take the Restart Network option in the resulting window.
Message 6 of 27
I have now tried again with the settings but this time is says "Reboot" and once I click reboot now it just says failed try again.
Message 7 of 27
Hi @Legend2
You have only done part of the configuration work. You have not edited the settings in the Lease Range section to be:-
Subnet IP: 192.168.2.0
Subnet mask: 255.255.255.0
Starting IP: 192.168.2.10 (anything from 192.168.2.2)
Ending IP: 192.168.2.254
Message 8 of 27
Can you please PM me (to preserve your privacy) screenshots of the DHCP & NAT page, plus the Home tab of the eero app?
Message 9 of 27
I've just tried the settings you suggested above, it seems to be connected, but the internet isn't working.
Message 10 of 27
SGM can be useful in certain circumstances, as it is a form of Quality of Service (QoS) to prioritise certain IP packets locally within the eero mesh network.
It looks like the app or an eeroOS update has slightly changed the options, 192.168.0.0/16 will do.
Message 11 of 27
Interestingly I just put the SQM setting on in the EERO app and it seems to have magically fixed my bufferbloat completely. On the Waveform website when testing for bufferbloat, I was getting a D grade, with the SQM setting on it's now A+. Could this one setting alone really be that good?
Message 12 of 27
Hi Keith, I just set it up and had a look at the settings. I can't see the prefix 192.168.0.0, the closest I've got is 192.168.0.0/16
Message 13 of 27
Hi @Legend2
Assuming that the Sagemcom is using the default IP network 192.168.1.1/24 IP network where its IP address is 192.168.1.1, you could configure the eero to use the 192.168.2.0/24 network.
To configure this in the app, go to:-
Settings > Network Settings > Network Services > DHCP & NAT
Select Manual IP, then set the IP address prefix to 192.168.0.0 and input the IP address range.
Typical settings are:-
Like this, the router will allocate itself the address 192.168.2.1.
Now, tap the Save button at the top right of the window and a message will be displayed saying that the eero needs to reboot. Accept this & wait until it has done this.
Message 14 of 27
Okay, thank you. It is a traditional mastersocket so FTTC.
Message 15 of 27
If it's coming through a traditional mastersocket, you have FTTC, @Legend2.
You'd know it was FTTP by a different sort of box on the wall etc.
Message 16 of 27
The max speed for my area is 75mbs, so I'm guessing we have FTTC.
Message 17 of 27
This can be delivered over full fibre or FTTC, which do you have?
Message 18 of 27
Ah, I've possibly posted in the wrong board? I'm with Talk talk 65.
Message 19 of 27
Hi @Legend2
I have noticed this thread is in the full fibre board. If you do have this service, then just connect the eero to the ONT and forget about the Sagemcom. There will then be a further complication, who's full fibre do you have, as CityFibre needs a special profile for an eero.
Legend2
Message 20 of 27
I don't have much knowledge if I'm being honest, but would love any help/steps if you find the time later.
