Router won't turn on
Message 14 of 14
Good morning
I woke up this morning to find that my wifi router is off and won't turn back on. I'm not sure if it's a problem with the power supply or the router itself.
Are you able to assist me with resolving this?
Kind regards
Craig
13 REPLIES 13
Message 1 of 14
Hi Craig @craigndavies
No problem 🙂
I've ordered the router now, please allow 48hrs for this to arrive.
Message 2 of 14
Hi Debbie. OK yes please could you place the order now.
Many thanks for your and Michelle's help with this.
Kind regards
Craig
Message 3 of 14
HI @craigndavies
If I order this now, we usually advise 48hrs for delivery.
Would you like me to order the router today or wait until Monday morning and then order then?
Message 4 of 14
Thanks Michelle - yes a replacement router would be ideal. Would it be possible for it only to be delivered sometime from Monday 21 October onwards?
Message 5 of 14
Hi Craig,
Thanks for confirming. Are you happy for us to send you a replacement router?
Message 6 of 14
No, the LOS light is off. The power light and the PON light are on.
Message 7 of 14
The LOS light on the ONT is not on is it?
Message 8 of 14
I've double-checked the cables from the ONT box to the router - and jiggled them about a bit - and they all seem fine. It might be worth running a test on the line again just to make sure?
There are two green lights on the ONT box, but no light at all on the router.
Message 9 of 14
Thank you. I've run a test on your line now which has asked us to check that all the cables from the ONT to the router are all connected securely. If you've already tried this then please let us know and we can send a replacement router for testing purposes. Are the lights ok on the ONT box?
Message 10 of 14
Thanks Michelle - I've updated my community profile to include my account number.
Message 11 of 14
Hi Craig,
Thanks, apologies could you also add your account number too please in your Community Profile.
Message 12 of 14
Hi Michelle.
Thank you for your reply.
I've updated my profile accordingly.
Message 13 of 14
Morning Craig,
Sorry to hear this and we can look into this for you.
  • Name
  • TalkTalk Telephone number
  • Alternative contact number
