on 02-04-2024 10:52 PM
Hi, I have set the SSID channel manually for the 2.4Ghz and the 5Ghz channels. However, this randomly changes at random intervals throughout the day, when looking at the router logs I can see that ‘channel hopping’ has been initiated remotely some how which changes the channel, despite being manually being configured by me.
This causes connectivity issues and results in online gaming sessions disconnecting mid game etc.
I would be grateful for any help in resolving this.
on 14-05-2024 10:36 AM
why escalated if you can turn this off? Did so in Jan. Thanks. Is there an actual tech support team I can phone, going back and forward on community forums is madness.
on 13-05-2024 01:18 PM
Hi kirkyboy4
I've asked our faults escalation team to take a look at this. The team may contact you directly to discuss this further.
on 13-05-2024 11:00 AM
Yes, if I was to set my hub to channel 100 or 104 before I went to bed by the time I woke up the channel will have changed back to 36/40/44/48.
I googled that and someone on Reddit had advised that this is something called Wi-Fi optimisation built into TalkTalk hubs, so I want that switched off so that stops happening?
on 13-05-2024 10:17 AM
Hi kirkyboy4
Your router has the latest firmware version.
Just to confirm, the issue is when you change your wireless channels to your preferred channels, it then changes back again?
on 13-05-2024 10:12 AM
Hello after restarting my router I am still seeing through the night in the logs "channel hopping was initiated automatically/manually", its not been as bad recently but still happening by itself, can someone also check my Router settings to make sure I've got things configured correctly and that I am running the most recent firmware/software for the hub? Ill paste some device info below.
Hardware Version: FAST5464 2.00
Software Version: SG4K100174
GUI Version: 5.100.1
System Up Time: 6d 00h25m20s
For the hub DNS, should I have the Static DNS Server Configuration filled in with TalkTalk primary & secondary DNS values or should I leave that blank to use the default settings, then within Internet Connectivity under "DNS IPV4" i have it set to obtain DNS automatically and its pre filled talktalk dns, is this the best way to have this configured?
on 10-05-2024 07:16 AM
Hi @kirkyboy4
If you do experience any further issues then please post back on this thread and let us know.
on 03-05-2024 07:54 AM
on 24-04-2024 06:41 AM
on 08-04-2024 08:10 AM
Hi kirkyboy4
Our Devices Team have asked if you can reboot the router and retest to see if you are still having issues with the wireless channels?
on 03-04-2024 10:10 AM
Hi kirkyboy4
Our Devices Team are just taking a look at this now and I will post back as soon as I have further information.
on 03-04-2024 09:50 AM
Hello, I've updated my community profile, got the badge for 100%, do you need any information from my router? I have the TalkTalk WIFI HUB 2.
on 03-04-2024 06:47 AM
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 02-04-2024 11:32 PM
I am assuming you have a Sagemcom WiFi Hub? Make sure that your personal details including TalkTalk phone number and/or account number are complete on your community profile (click here) so that the support team can link your forum identity with your account and then wait for them to respond.
