on 15-05-2024 05:41 PM
After turning our tele off on on again, ITV X has completely disappeared
on 16-05-2024 07:40 AM
Hi @ShanEth40
If you can let us know what model TV box you are using we cam offer further help.
on 15-05-2024 07:31 PM
Is this your TV Orr your TalkTalk box?
If your box, you will probably have either a 4k box or TV Hub.
If so then you would be best to do a factory reset to reinstall the app.
