Tv remote connection
Beth09
Message 8 of 8
Why can’t I open the menu when I press talk talk button on my remote. HD channels not showing up
7 REPLIES 7
Message 1 of 8
You're Welcome 🙂
Message 2 of 8
Thank you
Message 3 of 8
OK, you can try a Youview Maintenance Reset  to see if that helps.
If the button on both remotes are not working correctly with the box after a reset, then the box itself could be starting to fail.
Message 4 of 8
Yes it is a few years old
Message 5 of 8
Is it one of the older TV boxes, so a few years old, not the new streaming box ?
Beth09
Message 6 of 8
Hi can’t see model number but everything is working apart from menu button on remote. I’ve bought a new remote but still the same problem
Message 7 of 8
What model TV box do you have ?
With regard to HD Channels, connect aerial direct to TV and see if the HD channels show or if there is any breakup of the signal.
