UNFINISHED FIBRE INSTALL
1 REPLY 1
I have recently had UFO fibre installed which has been great as of late.
The cable to my property is fed from the telegraph pole opposite (as seen in photo)
My worry is that the actual fibre cable that's run up the pole from under the pathway is still exposed, and secured to the pole with the yellow tape.
This worries me and my neighbour's as if the cable was to get snagged or caught with something we would be without internet .This would cause me problems as I work from home allot.
The exposed cable should be covered with a metal conduit as the cables on other poles are .
I maybe posting this in the wrong forum, but wanted to make someone aware from Talktalk to escalate it ,possibly get it rectified asap before the inevitable happens.
Obviously if someone gets in touch from talktalk I will give the address .
Martin
M Nettleton
Hi Martin,
I'd recommend contacting our dedicated UFO Team directly as they will be able to look into this/advise further.
 UFO Support Team
