Down from 50mbps to 10
Omniash
Message 12 of 12
Can anyone help? I have spoken to online chat twice and after doing so for 2 hours I haven't gotten anywhere.
Since the start of December my speed has dropped from 50-60mbps to 10. This is proving completing essential work for my job difficult.
Thank you.
11 REPLIES 11
Message 1 of 12
Hi Omniash
I can see a router has been ordered for you and should be with you soon.
Skynet_TX
Message 2 of 12
If you are getting slow speed test results on a wired device, then have you tried switching the router off for over 30 minutes ?, this will ensure you get a new session when you switch it back on.
Message 3 of 12
Late reply but.
I have done all this. still getting 10. I have been on live support chat for a total of 6 hours now with them still "doing checks". I will like a new router for free as it is 100% this issue. Can someone confirm?
Message 4 of 12
Hi Omniash
If you could check directly wired to the router this will at least rule out a wireless issue if the speed over the wire is approximately the same as the wireless speed
Message 5 of 12
Hi Chris.
Yes I am. A test I just completed shown 17 Megabits per second. I have also tested the wifi from my phone stood right next to the router and I get 20 Megabits per second. At the weekend I can try a direct wired connection but I don't see how this will be any different.
Message 6 of 12
Hi Omniash,
Line test is clear and router is currently in sync at 56.7Mbps, are you still seeing slow throughput speeds?
Message 7 of 12
Yes that is the number that appears on my account. I do not use a landline phone however.
Message 8 of 12
Just to confirm, is the telephone number in your Community Profile correct? Please do not post any personal information on the Community.
Message 9 of 12
Hi Michelle,
I have completed the above. I am still getting extremely slow speeds.
Message 10 of 12
  • Name
  • Telephone number
  • Alternative contact number
Skynet_TX
Message 11 of 12
Hi @Omniash,
Are you referring to the router sync speed, or a speed test result that has dropped in speed. If it is a speed test, then are you doing this from a wired or wireless device, it is best to use a wired device to get accurate results.
If you were referring to a speed test result that has dropped to 10mbps then if you log into your router to check your sync speed has this dropped as well ?.
If the sync speed is still good, but your speed test results are much lower, then try switching the router off for over 30 minutes to get a new session in the street cabinet.
If your sync speed is also low then it would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem (although you may need to leave the router connected at the test socket for 72+ hours before you would start to see a speed increase if this was the cause of the problem).
Don't post any personal details in this thread, just add them to your community profile (only you and the TalkTalk staff on this community can see your profile details).
