IP address changes
Walshwalsh
Message 4 of 4
Why does my IP address keep changing?
I work from home and use software the allows me access based on my up address being under an ‘approved list’. But for some Reason turnip address keeps changing so I get chucked out of the work software.
Any idea why that might happen and how I can stop it?
thanks,
m
3 REPLIES 3
Birchcroft
Message 1 of 4
@Walshwalshif a fixed IP Address is esential then there are at least two providers that offer that facility.  (1) Plusnet at a setup cost of £5. (2) Zen.  More information can be found by following the link.
Message 2 of 4
Hi Walshwalsh
All residential ISP's provide a dynamic IP that will change.  fibre will not change very often, but if you have an adsl service this will change whenever the connection is dropped.
TalkTalk business do provide a static IP address so if this is important you may want to enquire about the cost of a business connection.
martswain
Message 3 of 4
TT do not offer a fixed IP address on home broadband contracts.
It will only change after a disconnection due to a fault, the user turning off or resetting the modem and possibly the router going to sleep due to a period of inactivity.
@Walshwalsh
What TT service and router do you have ?
