Intermittent WiFi dropout
Bailey22
Chat Champion
Message 117 of 117
I have recently experienced a problem with intermittent WiFi dropout that is becoming more frequent. When this happens and I interrogate any of my devices I get a message that says (words to the effect of) 'You are connected to the internet but there is no signal. Contact your Internet Service Provider'.
When the dropout occurs, the light on the front of the Huawei DG8041W-2.T5 router is rapidly flickering between red and white. Turning off the router and waiting 5 minutes before turning it back on clears the issue - until the next time!
Do I have a faulty router?
116 REPLIES 116
Message 61 of 117
Hello Chris
The network connection has been down again from 1015 to somewhere between 1130/1210.  So the service is totally unacceptable as it is.
Guess that I have no choice about the charges, although I will be very annoyed if I am charged. I can be available at any time on a weekday as long as I know when the engineer will be coming.
I hope that this can be arranged quickly.
Message 62 of 117
If you'd like us to go ahead with the engineer visit can you confirm:
Message 63 of 117
Hello Chris
The network connection dropped out again last night at 2030 and reconnected between 2130 and 2200. So it is certainly no use as it is and needs to be thoroughly investigated. So what details do you need to confirm?
Kind regards.
Message 64 of 117
Hi Bailey22,
If the connection is still dropping then we'll need to arrange an engineer visit. If you'd like us to do this please let us know and we'll confirm some details with you
Message 65 of 117
Hello Chris
Since my last post this afternoon, the network connection failed at 1724 and came back on at 1900.
Please let me know what action will now be taken to try to sort this out.
Kind regards
Message 66 of 117
Hello Chris
I am sure that you understand that I have not been able to continuously monitor it over the weekend. However, on Saturday morning at 0940 I noticed that the network connection was down. Shortly afterwards the router started rebooting and the connection was restored at about 0950. When I came home today at about 1500 the network connection was down, how long it had been down I do not know. At about 1550 the router started rebooting, the light going solid amber at about 1555 then turning white and the network reconnecting at a couple of minutes after 1600.
So, what happens next?
kind regards.
Message 67 of 117
Hi Bailey22,
How are you getting on, how has it been over the weekend?
Message 68 of 117
OK thanks. Could you see how it goes over the weekend, if the pattern continues and we'll check in again with you on Monday
Message 69 of 117
As I explained yesterday, the router arrived on Wednesday and was installed that evening. The wifi dropped out around 1330 yesterday (Thursday). So this router is performing exactly the same as the previous one and the one before that in 2023.  So the problem must be elsewhere.
Kind regards.
Message 70 of 117
I/m showing the router delivered, have you had a chance to test ?
Message 71 of 117
Sorry, it was Tuesday that it dropped out from 1430 to 1600, not yesterday.
Message 72 of 117
Hello Karl
I will do that  but for the past week or so it has been dropping out on a daily basis around midday or early afternoon. Yesterday it dropped out at about 1430 and came back on at about 1600. Looking at the original post I made on 30 December 2023 it would appear that I am having exactly the same problems now as I was experiencing then.   I have had 3 different routers showing the same symptom so I do not believe that it is a router problem.
I am sure that you understand just how frustrating and disruptive this so I am anxious to get this resolved permanently.
Kind regards.
Message 73 of 117
I've ran a couple of tests across your line.  All is clear at the moment with no issues detected.
Lets see how it behaves as we go into the weekend. If there are drops, make a note of the date / time and we can then check these against the Openreach DLM Logs.
Message 74 of 117
Hello Michelle
The new router arrived yesterday and I installed it last night. It has worked fine until about 1330hrs About 30 minutes ago) when the connection dropped out. All my home devices showing a good connection to the router but no access to the internet.
I restarted the router and after going through its starting up procedure it showed a solid amber light until a couple of minutes ago when the light turned solid white and everything returned to normal.
I don't think it's a router problem but there is certainly something strange going on.
Grateful for your further help.
Kind regards.
Message 75 of 117
Great, thank you 🙂
Message 76 of 117
Thank you Michelle. I will certainly let you know how the connection compares.
Thank you very much for your help.
Message 77 of 117
The router is on the way and should arrive in the next 48hrs. Please let us know how the connection compares.
Michelle 🙂
Message 78 of 117
Hello Michelle
No, I am not using any wifi extenders but I would be happy to try another router. It is a shame, as this Sagemcom router has been the best I have had and been really stable until the past week or so.
Thank you so much for your help.
Message 79 of 117
I've run a test on your line now which is clear. Are you currently using any wifi extenders? If the tests are clear then I would suggest trying a different router. Are you happy for us to send this?
Message 80 of 117
In 'Track my fault' in 'My Connection' on my account it is now telling me that a case has been opened reference REP-14918340.
