Losing internet connection 50+ times a day
mrbendy
Message 12 of 12
My internet connection is constantly dropping.  It works for two days then goes mad for two days, then works for a few days etc it's completely random. I've tried 3 different routers and this happens with all of them. I've tried using the direct connection by using the test socket with the same results
Router- HG633
hardware- H.1.01.
software- v1.21.
thanks
11 REPLIES 11
Message 1 of 12
No Problem 🙂
Lets see what Openreach can find out.
Message 2 of 12
Hi, the phone's been fine, no crackles as such. thanks for the quick response.
Message 3 of 12
Can you check the home phone and confirm there are no crackles on the line, just a clear dial tone ?
Tests are showing a possible copper joint issue.  I've raised a fault to Openreach so they can take a look.
Message 4 of 12
I've had the router up & running for three days, unfortunately all the issues have remained the same.  What now please?
Message 5 of 12
You're Welcome 🙂
Message 6 of 12
thanks😎
Message 7 of 12
A router is on the way to you.
Message 8 of 12
yes please, thanks😀
Message 9 of 12
Thank you. I've run a test on the line now which is clear, however I can see some re-connections on the line. The HG633 is one of our older routers. Would you like us to send a replacement router for testing purposes to see how the connection compares and to rule this out?
mrbendy
Message 10 of 12
Profile Updated.
Message 11 of 12
  • Name
  • Telephone number
  • Alternative contact number
