Speed test via service centre asks for WiFi connection
jayesjay
Whizz Kid
Message 12 of 12
This is not, at this moment, a complaint about speeds - I've just moved to Fibre 65, and speed is slightly improved over Faster Fibre - previous package.
My complaint is that navigating through the Service Centre to its speed test, I am asked to name devices connected via WiFi. Except for temporary usage of WiFi devices, all my devices commonly in use are connected via the wired LAN.
I have commented on this some time back, when I had a reply of,  effectively, "We are unable to test without WiFi."
What I want, usually is the speed to the router, and I use the Thinkbroadband speed test. It would be nice, however if I could get your active speed test - rather than the previous night check, which seems to the other way via the Service Centre.
11 REPLIES 11
AllyM
Insightful One
Message 1 of 12
I'm afraid I'm still not seeing this issue about requiring a WiFi connection. It must just be affecting some customers and not others. The Service Centre is a shambles though, I reported issues with it some time ago and nothing got fixed so I wouldn't hold your breath that they will fix this issue for you either.
jayesjay
Whizz Kid
Message 2 of 12
This  need, to connect with WiFi, has occurred only in recent months; I couldn't say when.
Message 3 of 12
@jayesjay wrote:
Using these "external" speed tests doesn't alter the fact that the TT speed test via the Service Centre requires at least a temporary WiFi connection.
I've used the TalkTalk service centre speed test many times on my PCs connected by ethernet and no wireless devices connected. I've never once had and message asking me for a WiFi connection. Am I missing something?
jayesjay
Whizz Kid
Message 4 of 12
I note that support-test uses OOKLA which for at least some time was also the speed test used, or at least displayed as the "publicly" available test via the TT Service Centre links.
I note the samknows test shows as slightly lower than the others (on one pass).
I did try this using my phone, and it worked OK. So the status quo is as described by Chris.
Summary: I ran:
1) OOKLA : 32.5
2)supportal-test (also OOKLA) : 32.7
3) samknows : 32.8
4) thinkbroadband: 32.9 bursting to 35.1 (tbb uses two different configurations, single thread and multithread.
5) TT Service Centre, with WiFi connection:
To Router: 29; To Phone: 29 (Samknows gave same result with phone connected. This was at variance with the last midnight value:
"Speed to your Router
Est. speed: 26 Mbps - 32 Mbps
Measured speed: 35 Mbpsa"
Thanks all for your contributions.
Message 5 of 12
Hi jayesjay
It's also good practice never to rely on just one speed test as they can all give a different result, based on location, server load etc, so I always use a couple to get an average reading.
I've always found sam knows speed test to be a useful comparison.
https://speedtest.samknows.com/
Message 6 of 12
jayesjay
Whizz Kid
Message 7 of 12
I did a couple of tests/
1) Tried printing with  my HP inkjet via WiFi.  Had a problem there with speed measurement, although it printed Ok. Let's not worry about that.
2) Also I turned on WiFi on my mobile phone, and there was a successful speed measurement to the phone (33M)
Outcome, more or less OK. It works as stated, I'll not worry about the inconvenience so long as I can use thinkbroadband for a quick measurement.
Thanks for help, all.
jayesjay
Whizz Kid
Message 8 of 12
Thanks, Chris.
Even so, I might as well list the response:
"Your devices need to be connected to your TalkTalk home network
via WiFi."
Message 9 of 12
Aha I can see what's happening there: click on the link above; srcoll down to Check your speed; click there and it should take you to a live test.
Message 10 of 12
Chris-TalkTalk
Message 11 of 12
Hi jayesjay,
I'm sorry about this, we have raised this previously and it may be something that's looked at in the future, apologies for any inconvenience.
