Windown 10 Pro PC won't connect to Wi-Fi on power up
galvinpaul1718
Message 4 of 4
Tried lots of things but it has been suggested by the manufacturer support that it might be a router issue ..... Never had an issue on my old PC on win7 and 2.4G.
Both mine ( Lenovo) and the wife's PC ( Acer) which are new and on win 10 have the same problem.
After bootup, the PC hasn't auto connected to the 5G service.We have to manually connect, even though auto connect is ticked.
A re-boot will auto connect.
A shut down and restart will auto connect.
Leave the PC off for a while and it won't connect after boot.
Is there anything I can check ?
3 REPLIES 3
Message 1 of 4
If so, that proves it to be a WiFi interference problem.
Message 2 of 4
This is quite common, the first thing to do is to delete the connection & reconnect to it. Make sure that the WiFi adapter drivers in each PC are up to date. If this is on the 2.4GHz band, it could be down to Wi-Fi interference.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
Message 3 of 4
This is a strange issue, not seen this before. If  they will connect manually then there should be nothing wrong with the router. If there was, then they would not be able to connect at all.
As a test, you can try changing the SSID (wifi name) for the 2.4Ghz wifi channel.  Log into the router and change this and see if this has any effect.  You can always change it back later.
