Grrr Wifi Hub disconnects
ANSWERED
MikeD66
And surprisingly 5ghz band has reverted back to channel 36 from the 100 I set it to not that anything was connected to it and a load more WiFi security setting saved messages in log
MikeD66
Against my better judgement got fed up with waiting 2 hours for the internet to return so have re-booted the router despite devices being connected and that good ol' solid white light being on and as if by magic I have service again, not good in fact I am rapidly starting to lose my patience with TalkTalk, the iceberg lookout on the Titanic was more reliable than the fibre broadband I have experienced over the last week or so. I should not be having to turn a TalkTalk supplied router off and on every few days to restore service
I left my last bb supplier over costs sadly I am starting to think bad decision as I had probably a dozen or so outages in 20 odd years with them and that was usually local network outages impacting whole post codes and not this, how do I put it politely, rubbish stability I am looking into for the next 15 months
Sorry for the rant I know you guys trying to help but as a customer I am not seeing any real improvements in the service I am paying to receive, rebooting a router is not a fix its a temporary workaround as any ITIL qualified person will tell you
OCE_Michelle
Hi Mike,
I'm really sorry to hear this. One of the line tests is now showing a loop fault which can sometimes be caused by internal wiring or equipment connected to the line. Would you like us to send a different make and model of router for testing purposes to see how the connection compares and to rule out any issues with the router?
MikeD66
Yes please
OCE_Debbie
Hi MikeD66
MikeD66
New router received on Thursday/Friday finally got fed up with old router dropouts on sunday morning - nearly continuous -
first thoughts - looks exactly like the first router but under the covers it appears to be a different beast and model
a DG8041W with a totally different gui (which I like as its not dumbed down and actually shows decent info unlike the sagem)
now plugged in and working and loaded up with devices lets see how this one fairs - already showing bb speed back up to 32mps from 27mps so maybe a good sign
OCE_Debbie
Hi MikeD66
Please can you continue to monitor this and let us know how you get on.
MikeD66
Well I’ve had the test modem running for over a month now and initially stability was better than it had been. Sadly in the last week stability has degraded somewhat
it manifests itself most notably in online gaming where I can visibly see the latency in game going from 50 to over 500 to 999+ and repeated disconnects
this is repeated over different online games at various times of the day
ping tests are showing good sub 50ms times when successful however I see numerous request timeouts and lost packets when multiple tests are run in a row 25 pings regularly resulting in 25% packet loses which is not good and I think an issue with the fibre
OCE_Michelle
Hi Mike,
I'm sorry to hear this and I'll take a look now. I've re-run the line test which hasn't detected a fault and I can only see 1 re-connection on the line and the sync speed speed looks consistent. Are you currently connected wired or wireless when you experience the instability and latency?
MikeD66
Wireless on my laptop
Wireless on my ipad
when I see the latency in game I try to immediately alt tab out and use internet browser to see how that is responding and at times it’s slow to load a page
Just done a set of ping tests against www.talktalk.co.uk and www.bbc.co.uk
the first set to tt was ok no loss 16ms average 25 ping run sample
the second set to bbc had 2 packets lost 4% 12ms average 50 ping run sample
the third set to tt had again 2 packets lost and the average up to 20ms
OCE_Michelle
Hi Mike,
Ok thanks for confirming. Do you have any devices connected wired? Have you also tried separating the SSID's?
Split your router's SSID (wireless network name)
MikeD66
No devices wired due to location of router//modem , not tried separating the ssids on this router yet or the channels last time I tried that on the other router talktalks intelligent learning software would keep changing it back overnight ^^
laptop is connected to the 2.4 band
will try separating the ssid’s to see if they are interfering with each other but not too hopeful as the connection had been fairly stable for the last month aside from the last week with the ssids the same
OCE_Michelle
Hi Mike,
Thanks for confirming. As the line test is clear and the connection stats look ok from here then it would be worth trying this if it's not possible to connect wired, as this can sometimes improve the wireless connection. Please let us know how you get on.
MikeD66
Ok so I’ve change the ssid’s to separate the two band names
connected to band 1 (2.4) ran ping test wireless saw timeouts and lost packets
connected to band 2 (5) ran ping test wireless saw timeouts and lost packets
wired laptop via Ethernet cable ran ping test, marginal improvement in average response times by 2ms (so not a lot ) but still saw timeouts and lost packets
guess that rules out WiFi issues and we are back to router / line issues
OCE_Chris
Hi MikeD66,
Thanks for the information. Could you switch your router off for 30 minutes then switch back on and check to see if there's any improvement
MikeD66
Will try that when I return home early next week
router has been rebooted 3 times since receipt last time was 3 days ago but not left off for 30 mins
last reboot lowered the memory and cpu usages from around 20% to around 10%
OCE_Debbie
Hi MikeD66
Please let us know how the connection compares after the 30 minute power down of the router.
MikeD66
Hello there
got home this afternoon, powered down the router for 45 mins as suggested then powered back up
the good news was the first set of ping tests to talk talk was 100%
the not so good news the next 3 sets of ping tests to bbc, Google, talk talk all had request timeouts and lost packets (not as bad as before only 4% packet loss but still a loss)
the slightly better news is an hour online gaming has seen no disconnects and only a couple of moments of high latency
then the bad news I now on top of a shoddy internet connection have a talk talk landline phone with no dial tone and when rung nothing coming through. I won’t bother to describe my experience of using the online chat feature ....
MikeD66
Solution
Typed too soon didn’t i
packet loss now up to 20% and a disconnect from the online application I was on guess switching the router off for 30 mins didn’t resolve too much 😞
MikeD66
And a quick logon to the router is showing my fibre speeds to more than halved 38 to 16 download, 7.5 to 2.48 upload
