Slow fibre and dropouts
16 REPLIES 16
Wizz Kid
I am having dropouts several time a day, each one last maybe a couple of minutes.
My speed has dropped down to between 11 and 14 mbps.
I had this problem before and an OR engineer found a fault at the top of one of their poles..
This was fixed and my speed went to 35mbps and no faults were shown when he checked.
He came on Jan 7th and all was well for a while, however speed and stability slowly deteriated .
Can you help ?
Hi doughybread
I've completed a line test which has detected a possible fault. Are you experiencing any faults with the landline service when making calls? (noise)
Wizz Kid
No noise on landline Debbie !
Hi doughybread
Is the router also connected at the test socket? I can then raise this fault over to our Network Team for investigation.
Wizz Kid
Connected to test socket Debbie. And
Hi doughybread,
Thanks for the additional information. The line test is detecting the fault close towards the property. Could you also confirm if you've recently tested with an alternative router and I'll pass this straight over?
Wizz Kid
Sorry, do not have alternative router !
Hi doughybread
I can send a replacement router for testing, would you like me to arrange this?
Wizz Kid
Yes please Debbie, it's worth a try.
Hi doughybread
Wizz Kid
Hi Debbie,
Router arrived today, have connected it , but the speed is the same as other router.
I will leave it for a couple of days to see if there is any improvement.
Will keep you updated.
doughybread
Wizz Kid
Alternative router has been connected for 24 hours now, no improvement at all in performance!
This rules out the router as the problem I think.
Speed today down to 8 Mbps.
Hi doughybread,
As there's no improvement this is probably going to need an engineer visit. If you'd like us to go ahead with the engineer visit can you confirm:
I've also PM'd you to confirm some other details
Wizz Kid
Thanks Chris
next week am available Mon am & pm, Tues am & pm, Frid am & PM.
doughybread
Hi doughybread
Thanks for the PM, I've replied requesting a bit more information
Hi doughybread,
Our network team have confirmed that the engineer visit is booked for 26/02 AM (08:00-13:00) please let us know how you get on
