Black Huawei router rebooting
johnny95
Whizz Kid
Message 26 of 26
I’ve had the black Huawei router for a while now. At first it rebooted itself once every 1 to 2 months. However in the last couple of weeks it’s started rebooting several times a day.
I tried resetting the router to the factory settings (using a paper clip) This didn’t fix the issue. So I powered down the router for an hour. After this it stayed on for a couple of days but today it’s rebooted three times already.
Could it be overheating? Anyway please could you send out a replacement router to see if that fixes the issue? I didn’t have this problem with the previous router.
25 REPLIES 25
Message 1 of 26
Message 2 of 26
Hi, Debbie
To be honest I think it’s fine so you don’t need to do the tests. I’ll keep monitoring it and let you know if I decide to go ahead with them.
Thanks again,
John.
Message 3 of 26
Hi John
The connection will drop for a short time whilst I'm running the line tests.
Would you like me to run this tomorrow morning at 7am instead?
Message 4 of 26
Thanks for your quick reply. That would be great. As long as it doesn’t affect my connection now? If it doesn’t then please can you do that. I have a 65.1 mbps download. One other thing I noticed that my download and upload speeds were exactly the same as before which suggests the connection didn’t go.
Message 5 of 26
Hi John
The connection time could be wrong. Would you like me to run a line test and check if I can see any reconnections?
Message 6 of 26
Just a quick update. The Sagemcom WiFi hub 2 has been working fine and I have a faster connection compared with the Huawei. It’s been very reliable so far and has been online for 30 days exactly. However this morning I logged into my router settings and the “current connection time” data had just reset. However my connection never went off as I was online at the time. It stated online for 6 minutes but I had been using the internet at the time so I know it didn’t go down. Just out of interest can the “current connection time” be displayed wrong?
I’m just curious, but it’s been working fine so far.
Cheers,
John.
Message 7 of 26
Sure, I've sent one out to you now.
Message 8 of 26
Upon checking, unfortunately I don't have a returns bag. Would you be able to send one out?
Thanks again.
Message 9 of 26
No Problem 🙂
Message 10 of 26
Ok, thanks 👍
Message 11 of 26
If you can please. There should be a returns bag in with the router.
Message 12 of 26
Hi Karl,
My router has arrived. I’ll be connecting it later. Do I need to send the other one back? As I don’t want to be charged for it.
thanks,
John.
Message 13 of 26
No Problem 🙂
Message 14 of 26
Thanks, Karl.
Message 15 of 26
A replacement is on the way.
Message 16 of 26
Hi Michelle,
Unfortunately the router has rebooted twice this morning. So the firmware hasn’t fixed the problem. Please could I try a replacement? I’m thinking of purchasing an Amazon Eero to use with an Openreach white modem which I originally had from TalkTalk. Would you be able to send one out for free or only the black Huawei?
Message 17 of 26
Thanks for the update and we'll check back in with you in a few days to see how you're getting on.
Message 18 of 26
Ok thanks, Karl. I’ll keep monitoring it. So far it’s been online since Friday afternoon.
Message 19 of 26
I've made a change to the firmware, see if this helps.
Message 20 of 26
Unfortunately I can’t find anything stating edit. I’ll have to wait for the support team, next week. Maybe it’s the power adapter for the router, I’m not sure. Thanks anyway.
