on 23-12-2023 09:40 AM
My connection keeps tripping out / buffering .
Had 3 separate technicians visits and new router.
Works fine for a day and next days keeps tripping out / buffering.
Can anyone help?
on 16-01-2024 01:59 PM
No problem
on 16-01-2024 01:56 PM
Hi Chris 🙂 ,
Great , fingers crossed this time too . Thank you.
kind regards,
Anil.
on 16-01-2024 01:50 PM
Hi Anil
I've just run another line test and it's failed so I've raised this to Openreach as a non-appointed task. Openreach will investigate over the next 72 hours and may contact you directly if they need to access your home
on 16-01-2024 11:10 AM
Hi Anil,
When we arrange an engineer visit we expect them to fix the issue if it's a problem on the Openreach network. If they don't fix the fault then the only option would be to arrange another engineer visit
on 16-01-2024 10:50 AM
Hi Michelle 🙂 ,
Am not getting a clear answer : what happens after the engineer 'clears the fault ' , i get charged and the issue is there ?
kind regards,
Anil.
on 16-01-2024 09:48 AM
Ok thanks for confirming. If you would like to go ahead with the engineer visit then please let us know and we can book this in for you.
on 16-01-2024 09:44 AM
Hi Michelle 🙂 ,
No its not weather related .
I suspect a faulty cable from connection at top of house to actual connection point to socket but then the engineers keep on saying ' could be anything anywhere at anytime ' !
kind regards,
Anil.
on 16-01-2024 09:40 AM
How often would you say that this happens? Does it appear to be weather related at all?
on 16-01-2024 09:36 AM
Hi Chris 🙂 ,
I read the potential charges - looks like its £75 for a BT Openreach engineer . Reading the information it says ' if no fault found the charges apply ' .
The fault is random - it may not show up when he's here doing the checks and reports back saying all fine .
I get charged but the issue is still there - what happens then ? Another visit , another charge ?
Anil.
on 16-01-2024 09:26 AM
Hopefully they will fix the issue this time but if they don't the only option we have is to arrange yet another engineer visit
on 16-01-2024 09:22 AM
Hi Chris 🙂 ,
That he has and i appreciate it.
My question to you is this : what happens after the engineer has been and ' cleared the fault ' but i still have the same issues afterwards ?
Anil.
on 16-01-2024 09:14 AM
Hi Anil,
I can see that Gliwmaeden2 has answered your question. If there's a fault found on the Openreach network then you won't be charged. If you'd like us to go ahead with the engineer visit please let me know and I'll book it for you.
16-01-2024 08:58 AM - edited 16-01-2024 09:00 AM
It's simply that Talktalk can't request engineers to be sent out without the customer first agreeing to potential charges, @puregold24carat.
Openreach simply won't agree to it, so Talktalk's hands are tied in this respect. The link given in Chris's earlier post explains the scenarios in which you would be charged.
on 16-01-2024 08:48 AM
Greetings 🙂 ,
I have not had a response from Chris to my question above .
So some background to this issue. I am a TalkTalk customer for past 20+ years ( i think ) and my contract was about to expire last November. I was on basic broadband and it worked fine , yes no issues . On the renewal the fibre 65 option seemed best so opted for it.
The issues started soon after . The internet would trip out . The router would flash red and then red / white and then white for a service.
This issue was quite random and happened several times a day. Did a line test and it failed. The first engineer came round and carried out tests and said the speed was low. He snipped wires at the and re- plugged the socket back it . Did few tests and said yes its fine. He said to give it a few days to see how it goes and left . The next few days were similar to before but seemed to lesser drop outs . We are both retired and wife watches TV more than i do . I play bridge online . Hence we note the drop outs more .
Carried out another line test . It failed . Second engineer came round . Carried out tests and said yes the issue is there . He said ' there was a drain ' on the internet . Now these kind of things are beyond me . He said he would fix . Snipped wires again and tests done . He said the issue ' could be anywhere ' and after doing some more work said it was fine but suggested a new router needed . This re requested . Said to wait for it to arrive and that should do the trick . He left. We noted on some days the internet was 100% and others days it would drop out at random times several times a day.
The new router arrived and i connected it . There was no improvement . Carried out a line test. It failed . Third engineer came . He did tests and was of the view the issue may be the cable that ran from BT line to cable that ran underneath the concrete floor. He said perhaps to drill and lay a cable above the shirting board would clear the issue . I asked him how long would that take and what if the issue still prevails afterwards ? He did not give me a reply . Carried out a few more tests and said the readings were fine. He left saying to leave it for a few days ( like concrete waiting to dry ? ) and left me his number to update him . I did a few days later saying the issue still there . He said to contact my service provider . I carried out a line test . It failed again.
Fourth engineer came . Line tests done . I related ( as i did with other engineers ) of the issue . He called his mate who arrived and they ran a cable from BT line thats inside the house to run outside along the bottom of outside wall and drilled in a new connection point inside house. Socket relocated to this new point . More tests conducted . It looked very promising . He left ( again saying to give it a few days and left me his number too to update him ) . The issue still there but the drop outs were few. Line test conducted. It failed .
Fifth engineer came round . Carried out more tests after my update . He called in for assistance as he decided the issue could be anything but to start with the line coming from the pole outside to my home. Another engineer came with a hoist to fix a new line from the pole to the point at the top of the roof ( above the top window ) . There is a further line the comes down from here to the main line that comes into the house ( this is where the issue maybe ? ) . After line attached , no internal tests done . He said the ' line was too tight ' and was happy they had installed a new line and was confident the issue is now resolved . He left . The connection is a lot better - still trips out at random times for a couple of minutes . Line test carried out . It failed .
The above is the fully story - from November to now .
So my question to Chris - TalkTalk has an obligation to provide a service . That its doing the best it can . I understand that . Why should i now have to pay for an engineer to fix the fault ?
on 15-01-2024 03:53 PM
(1) is there a fault right now on the line ?
(2) if the answer is yes then send an engineer to fix - without the worry of a charge hanging over my head.
Anil.
on 15-01-2024 03:48 PM
Yes I can see that there have been disconnection but we can only arrange the engineer visit if you confirm that you accept potential engineer charges. If a fault is found on the line there will be no charge
on 15-01-2024 03:46 PM
Why charges - you can see its fails the connection test ?
This you have confirmed too .
Anil
on 15-01-2024 03:42 PM
We can only arrange the engineer visit I'm afraid, it would be up to the engineer what work is carried out.
If you'd like us to book the engineer can you confirm:
on 15-01-2024 03:35 PM
The cable that's been changed ( from pole to top of roof ) , this cable needs to extend to the main socket to get a ' clean ' line of connection into our home .
So the issue needs to be sorted and i think this may solve the issue ( fingers crossed mate ).
The decision is yours .
on 15-01-2024 03:26 PM
OK thanks Anil. We can arrange another engineer visit, would you like us to do this?
