Restricted mode turned on by your network administrator...
WaRRioR1976
Whizz Kid
Message 38 of 38
Restricted mode turned on by your network administrator to help hide potentially mature videos...This is the message I'm getting on YouTube which means I can't view some videos via my smart TV or smartphone when connected to TalkTalk Wi-Fi. This is causing problems because some videos are unavailable for me to watch. I'm not talking about "adult" videos, just clean music videos that don't contain nudity or bad language.
I've switched off Kidsafe on my TalkTalk account but that hasn't solved the problem. Why is restricted mode switched on? I didn't ask for it to be switched on and I'm not a child, I'm 49.
Please can someone tell me how to fix this. Thank you.
I'm a drummer in a very well known band, I'm also a world class racing driver and crazy golf world champion 7 years in a row.
37 REPLIES 37
Message 21 of 38
As ferguson advises, Homesafe is DNS based, so using google DNS will bypass all homesafe settings.
Message 22 of 38
@IanLewis
Just so you know, using non TalkTalk DNS servers means that any Homesafe features will no longer work.
IanLewis
Message 23 of 38
I have this problem too. I haven't turned Scam Protection off, but changing the DNS server (to 8.8.8.8, google's DNS) seems to work around it for me.
Any idea when this might be resolved?
Message 24 of 38
If this is resolved by switching off scam protection, then obviously this feature has something to do with affecting this.  Scam protection is usually there to disable things like remote connection software, so I was not aware that this was affecting the setting in youtube.
Billx
Enlightened One
Message 25 of 38
Hi, @WaRRioR1976
Alright, this how to do it while in your home network:
Go to you TalkTalk MyAccount at https://service.talktalk.co.uk/myaccount/dashboard
Click 'Manage your Wi-Fi security' (Homesafe)
Set Kid Safe                  to OFF
Set Scam Protection to OFF
Set Virus Alerts           to ON
Also when you are in YouTube,
Click on the vertical 3-dots, which are next to the sign-in button on the top right
On the dropdown menu,
Set Restricted Mode to OFF
Bill
Cuptie
Sightseer
Message 26 of 38
I had the same problem and switched off scam protection as recommended by dsgsdg and Ican now view You Tube comments…..so this problem is definitely on Talk Talk Karl.
Cuptie
Sightseer
Message 27 of 38
I am having this same issue on iPad and my android phone is there a way to resolve this problem yet?
thanks
Message 28 of 38
definitely sounds like a setting forced by TalkTalk needs them to change something no matter what their support says - as you say it works when connected to non TalkTalk network - connected to my 4g hotspot works as expected.
Message 29 of 38
That's exactly what I was thinking. Why are mundane comments like "I agree with what you've said" being blocked? I don't have young children so don't need safesearch filters. If I don't want to view adult material, I won't. Simple as that.
Message 30 of 38
Hi Karl,
If my TV or phone is connected to Wi-Fi I can't switch off restricted mode. I can, however, switch restricted mode on or off when connected to 4g. Google search also has safesearch activated which I can't turn off when connected to Wi-Fi. Again, I can switch Google safesearch off when connected to 4g.
dsgsdg
Message 31 of 38
Yes, I previously had active a filter that blocked adult sites but the options in settings are different now.
If they are blocking something as mundane as youtube comments under 'Scam Protection' then it's fair to assume other stuff that should not be restricted is being restricted.
I'd rather just do without the filter than have random stuff that I don't want blocked being censored.
Message 32 of 38
Hi dsgsdg,
I'm having the same problems with being unable to view comments while connected via Wi-Fi. As soon as I switch to 4g mobile data, I can view comments and all videos,  and restricted mode switches off.
I don't know if I'd feel comfortable switching off scam protection but I'll try it later and see if that solves the problem. Talktalk scam protection also has safesearch filters which blocks "adult" content. I'm not sure why the safesearch filters can't be activated separately.
Message 33 of 38
On the Device or PC, whilst it is connected via your talktalk connection, click on your profile picture - usually top right corner of youtube page.   Down towards the bottom of the menu you should see restricted mode.  Try toggling it on and off.
Message 34 of 38
Hi Karl,
I'm not sure it's a YouTube issue because if I'm using 4g mobile data, YouTube restricted mode is off. As soon as I switch to TalkTalk Wi-Fi,  YouTube restricted mode is on.
dsgsdg
Message 35 of 38
So I had the same issue. Talktalk started restricting youtube content (no comments at all visable) within the last few days.
I confirmed it was not a Google issue as Youtube worked as normal on mobile data with another provider.
The only option that was enable in talk talk settings was 'Scam Protection'. I disabled that and now youtube is working normally again.
Message 36 of 38
This is a setting specific to youtube, and not a setting imposed by TalkTalk.
If you use Google you can search for the relevant answer.
Billx
Enlightened One
Message 37 of 38
Hi @WaRRioR1976 ,
In your Google YouTube account , have you entered your correct date of birth?
Bill
