alternative routers
Riley321
Whizz Kid
Message 59 of 59
I have a sagecom fast 5364 wifi hub which is having multple disconnections although some are only for a matter of seconds, The logs show that there are constant errors with the message DNS resolution failure and the router speed fluctuates. The router incoming speed is 75-77 mbps but only 67-68 mbps on the output side regardless of how many household items i have attached. I have rebooted the router several times including taking the router back to factory settings. The output of the router including the disconnections are measured using a Sam Knows white box which monitors the router performance for Ofcom. Does anyone have any ideas on how to a) resolve the DNS failure problem. b) solve the problem of the unit disconnecting, c) obtain a reasonably constant speed. Failing this advice on alternative affordable routers would be appreciated. Note that the line has been checked and everything seems to be fine. If i contact technical services all they do is run through the same check list finishing with a test where you have to re-contact them where the list is repeated.
Riley321
58 REPLIES 58
Message 41 of 59
Are the Ethernet speeds generally higher than wifi?
Message 42 of 59
a mix of wifi and cable  mainly though wifi
Message 43 of 59
Are those devices connected to your router by Ethernet cable or wifi?
Message 44 of 59
if you do a speed test in my account the speed to some of my items is 22mbps up tp 50mbps
Riley321
Message 45 of 59
Hi Chris
telephone socket to router 75mbps house side of router 67mbps most times it can drop during peak periods
Riley321
Message 46 of 59
OK thanks, what sort of speeds have you been seeing?
Message 47 of 59
Hi There
first disconnection was when Karl updated the firmware, 2nd one was me rebooting the router as a couple of failures happened, the attached word doc is a copy of the log file today.
regards
Riley321
Message 48 of 59
Hi Riley321,
Line test is showing a couple of reconnections yesterday, did you reboot the router yesterday?
Message 49 of 59
Hi Karl
Just checked this morning and the router log still shows multiple DNS failure errors occurring and speed is a bit erratic although does not cause a problem.
Riley321
Message 50 of 59
You're Welcome 🙂
Message 51 of 59
Hi Karl
Thanks for updating router, just looked at logs and all showing info (not error) Will keep an eye on it but hopefully it is sorted.
Riley321
Message 52 of 59
update completed. Firmware showing as V158 now, see if this helps.
Message 53 of 59
i'll push it now.
Message 54 of 59
Hi Karl
logging off now for a couple of hours
regards
Riley321
Message 55 of 59
Hi Karl
I will log out and the router will be free for a couple of hours, I would assume that the router will run through a restart procedure so i will know once the light goes back to white after the start up
Riley321
Message 56 of 59
your router is currently on V136. There is a later version just rolling out, V158.
When we update the router it can knock you offline for about 5 to 10 minutes.
When is the best time to push this.
Message 57 of 59
Hi Karl
That would be great as i do not know the version of software but if you were to update it to the latest then at the very least it should fully reset the router.
Riley321
Message 58 of 59
Would you like me to update the router to a later firmware and see if that helps ?
