Please Check My Phone Line?
CaptainNemo
Whizz Kid
Message 56 of 56
Is there any chance someone in support could check my line at the moment. It seems to be dropping out and massive packet data loss!
Nothing has changed and it's been stable for weeks if  not months.
Something isn't right?
There seems to be massive crackling on the line today and I've just run a connection test on the TT website and it says there is a problem -help!
TIA Steve
55 REPLIES 55
Message 2 of 56
Thank you.
Message 3 of 56
Message 4 of 56
Hi CaptainNemo
I will check the engineer report.
Message 5 of 56
Ok, will do 👍
Message 6 of 56
@CaptainNemo, as it's a billing query, just post about this specific issue in the billing section of the forum
If the charges don't stand, they'll sort this out for you.
Message 7 of 56
The last thing the engineer said to me is that there would NOT be a charge as the BT cable connection to the house was perished. This was outside the house and nothing to do with anything inside the property or any devices attached. He was a really nice guy and assured me there would NOT be a charge as I asked him specifically about this.
Steve
Message 8 of 56
Their wording is somewhat nuanced, @CaptainNemo, as below:
We'll charge you if the Openreach engineer was unable to find a fault with your service or the fault was found to be related to a condition in your property or garden. Any faults related to your main phone socket may also incur a charge, as will issues caused by any personal devices connected to your line. You won’t be charged for faults caused by Openreach equipment.
CaptainNemo
Whizz Kid
Message 9 of 56
Hmm, I’ve just received a bill from TalkTalk for £115.91 for the engineer who called, despite the fact that he found the fault outside my property…
How could this have happened?
Surely this is an error as I have always been told (and agreed with yourselves) that I would only be charged if there was a fault “inside” my property - and this was most definitely outside?
Steve
Message 10 of 56
CaptainNemo
Whizz Kid
Message 11 of 56
Thanks Chris 👍
Message 12 of 56
Hi Steve
Yes I can confirm that DLM has been changing your profile in the early hours of the morning over the last few days
CaptainNemo
Whizz Kid
Message 13 of 56
Hi again Michelle/Debbie, just checking that all the disconnections and reconnections I've had in the last couple of days (in the middle of the night) are part of the settling down period - the DLM?
What do you think?
Steve
Message 14 of 56
Thanks for your kind words Steve and please let us know if anything does change.
Michelle 🙂
CaptainNemo
Whizz Kid
Message 15 of 56
Wonderful - thanks again - you guys in support are how support teams should be!!
Steve
Message 16 of 56
Morning Steve,
Thanks for the update. The line test is clear, the sync speed looks stable and I can also see the one re-connection on the line. There are also no errored seconds showing here. If it's not affecting the overall performance of your connection then I wouldn't worry too much about these errors.
CaptainNemo
Whizz Kid
Message 17 of 56
Hi Michelle,
Here's the latest results from the router just now. It did reconnect on it's own about 1am in the early hours of Wednesday morning but maybe that's the readjustment period due to the DLM.
Also I'm not 100% how much packet errors are an issue or line attenuation figures - maybe they're fine - I don't know?
Steve
Speed and connection resultsSpeed and connection results
Message 18 of 56
Morning Steve,
How has your connection been over the last 48hrs?
Michelle 🙂
Message 19 of 56
No problem Steve, I'll check back in with you on Wednesday.
Michelle 🙂
CaptainNemo
Whizz Kid
Message 20 of 56
Will do - thanks again Michelle.
Steve
