WIFI Dead Spots around the house with FULL FIBRE 500
RazzOne
Whizz Kid
Message 5 of 5
Hi Mods
I have a dead spot in one of my bedrooms where my eero Pro 6 will not reach and my smart devices often struggle if we have lots of visitors in the house who all connect to the WIFI. The main issue is the Blind/Dead Spot in my daughters room.
With the very, very old/early router this wasn't a problem but with the Brilliant New Tech it is! 🤔
Is there anything you can do?
Cheers
4 REPLIES 4
Message 1 of 5
Hi RazzOne
I'm just sending you a Private Message to confirm some details so we can take a look at this for you.
Message 2 of 5
Hi @RazzOne
That is exactly as I said then:-
"The problem is that the Eero is designed to be part of a mesh network, requiring at least one more unit."
I will ask TalkTalk to consider your request, you may have to contact the Loyalty dept for them.
Message 3 of 5
Hi @KeithFrench
I am aware of all that and thank you for your help but my neighbour (also with TalkTalk) had the very same issue and they sent him more Mesh Routers. I have borrowed my fathers Eero (also on TalkTalk) and placed it as a second Eero in my daughter room, hard wired and the WIFI issue has gone but my dad wants his router back!
Maybe @Michelle-TalkTalk may be able to help if she still works there?
Cheers
Message 4 of 5
Hi @RazzOne
However, other factors should be investigated first. When this happens, what is the status displayed in the app for the internet connection? Do you have any wired connections & if so, how do they perform?
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
Whilst the Eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
