Home Phone
Landline problem
fitchett2406
Message 12 of 12
Broadband is fine, but can't use landline. Get the message that says you have looked into it, but can't ID the problem. Then we get link to bot that doesn't understand response.
Please could you get Openreach to look into this? Thank you.
11 REPLIES 11
Message 1 of 12
These links may be helpful
I can't make or receive calls - TalkTalk Help & Support
How to connect to your test socket - YouTube
Message 2 of 12
you sent us a text asking us to check our in-home set up. Link was talktalk.co.uk/yoursetup which wasn't found
Message 3 of 12
Hi fitchett2406
Thanks for your reply. I'm glad to hear that the connection is ok.
Which link do you mean?
Message 4 of 12
Seems to be okay at the moment, thanks. Tried to follow the yoursetup link you sent us, but it doesn't work!
Message 5 of 12
Hi fitchett2406
Just to confirm, has this fault been resolved?
Message 6 of 12
Hi @fitchett2406
Openreach have now closed the fault as resolved - Fault was at the cabinet.
Is everything working ok now?
Message 7 of 12
Hi fitchett2406
The fault has been assigned to a line engineer this morning, we should hopefully have additional updates later this afternoon.
Message 8 of 12
Hi fitchett2406
This fault is still with the Openreach line engineers, there are no additional updates at the moment.
I will continue to monitor for further updates.
Message 9 of 12
Hi fitchett2406
I've escalated this straight over to Openreach to be investigated by a line engineer.
I will continue to monitor for additional updates.
Indevar
Message 10 of 12
I've got the same problem and can't get any sense out of the web site. I'm sorry i stuck with Talk Talk!
Message 11 of 12
The support team here will be happy to help, but bear in mind that they won't be back online until Monday. In the meantime, you can try the normal contact channels:
