ITV X
TeeELL
Message 7 of 7
I have a new Talktalk Hub but ITVX doesn’t feature although it is supposed to be available.
6 REPLIES 6
Message 1 of 7
Do you have an aerial connected to your HUB. the ITV X App will not show unless an aerial signal is present.
TeeELL
Message 2 of 7
I have the same issue with my TalkTalk Hub (received 19 Sep 2024), I cannot get the ITV X app.  I’ve tried the ‘factory reset’ (not that it is called that!) it didn’t work.  I’ve finally worked my way to find the ITV X app - it states: “Your device isn’t compatible with this version”.
The whole point of getting the new hub was to address this.  I’ve tried the ‘chat’ but after connecting, finally, to a TalkTalk expert I received no form of communication - after a 15 min wait I’d had enough.  (Lots of ‘hello’, ‘are you there’ etc but no response).
Message 3 of 7
@Hutchisonalfred
Start your own topic and explain more how you can't i.e. on what device.
Hutchisonalfred
Message 4 of 7
I cannot get I'm a celebrity get me out of here live
Message 5 of 7
Do you have an external aerial connected to the box ?
Message 6 of 7
This has been reported before. A factory reset has usually restored this.
You can find the reset option within the settings menu.
Please let us know how you get on
Anonymous User
