No sound only pictures
Faith44
Message 11 of 11
I connected my youview box and there is no sound only picture. Can someone  help ?
10 REPLIES 10
Message 1 of 11
Is the box connected to you router? Direct or via power lines?
If you want a recordable box, there are Freeview play boxes available, plus you can buy YouView boxes from places like CeX or eBay. The BT pro box is the latest recordable box.
The apps on boxes vary and YouView boxes will not support ITVX.
Faith44
Message 2 of 11
I just did a complete factory reset and during the set up process it said we can't update software so I pressed skip. Then I continued with the set up and still no sound.  I contacted talk talk and they said I could subscribe  to talk talk4k box. However, it doesn't  have record function like the old model. I'm just not sure now because the record function is important to me.
Message 3 of 11
Have you tried the maintenance resets I mentioned? If it's not been used before do a factory reset from the menu.
These will ensure you have the latest software installed and check the hard drive is ok.
TalkTalk have not provided these boxes for nearly 3 years now, so a factory reset is your best option if the box can be saved.
Faith44
Message 4 of 11
I got it from talk talk but now they're saying that they discontinued this type of model.
Message 5 of 11
You may need to contact the seller where you got this from, as it could have a fault.
Faith44
Message 6 of 11
It's a DN372T.01.03.P
this the hardware version
Message 7 of 11
What model of box is this ?
Faith44
Message 8 of 11
It a new talktalk  tv plus box, never been used. I'm replacing it because the old one doesn't  record properly. I did  change the hdmi cable, I checked the volume on the remote,  its moving up and down but no sound coming out. I even retuned the channels,  I disconnected  and reconnected the box. The sound is on stereo, the antenna  is switched to out.
Message 9 of 11
try a the advice from fr8ys and see if this helps.
Message 10 of 11
Which box do you have? Has it previously been working?
I'm assuming you have tried changing the volume on the box using the remote. Has this gone to 100% or is it stating it's in surround sound mode?
Have you tried swapping the HDMI cable or checking its correctly in the box and TV?
In settings, the cog at the top right of the screen, try changing the HDMI output to surround, or back to normal depending on its current setting.
If none of these work try a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the support staff look at other alternatives.
Hope it works but if not then please let us know and support staff will get back to you.
