We've noticed the past two weeks that the 5Ghz signal on the router keeps dropping internet, so our devices need to connect to 2Ghz instead.
I've checked the other wifi signals to see if it's a busy channel but it all looks fine. I'm wondering if the router is beginning to fail.
Can we try using the newer routers to see if that fixes this issue?
I think the internet connection to the router is fine, it's the Wi-Fi from the router that seems to be faulty.
Hi salvagemachine
Can I just check if you have also tried factory resetting the router using the pin hole reset?
Hi salvagemachine
I can send a HG633 router for testing, would you like me to arrange this?
